Old 02-26-2016, 09:08 PM   #51
Originally Posted by doc73 View Post
Never seen a Walmart gas station..
Sent from my SAMSUNG-SM-G870A using Tapatalk
Well get ready, they are already coming with the new stores. Walmart is going to put in there own gas stations. Murphy has been the stations at Walmart but no more. The Murphy stations will stay but now Walmart will be in competition with them. Between my house and Wilmington NC on I-40 a new Walmart store selling diesel for $1.69, at my house 35 miles away $1.95. Forget going in there with a camper. I'll be going by there on 5 March, going to buy a 100gl
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-27-2016, 08:23 AM   #52
07 ThunderRoad's Avatar
Aux tanks
Originally Posted by cub22908 View Post
Thanks for the responses. An aux tank would be the perfect solution except that they are probably pretty much permanent installations. I do quite often use every inch of my bed hauling things. But I will do some research on this way of solving the problem. Dan
I installed 2 Sidekick 15gal tanks in my 2007 Dodge short bed.
https://titanfueltanks.com/shop/tita...-tank-5040015/
2013 Sanibel 3600 5th, 2007Dodge 2500 Cummins Turbo Diesel, 2WD, 4.10gears, Banks equipped, 18" factory rims
07 ThunderRoad is offline   Reply With Quote
Old 02-27-2016, 08:31 AM   #53
They fit well in the front of the bed.
Old 02-27-2016, 04:52 PM   #54
I use the truck lanes and have never had a problem. Both Rams that I have owned take the larger truck pump and can fill a tank in no time flat.
Crambo is offline   Reply With Quote
Old 02-27-2016, 07:27 PM   #55
Who Dares, Wins
doc73's Avatar
Mine was tight but it fits in my Chevy.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-28-2016, 11:27 AM   #56
I've used the truck lanes often when I owned my 2006 VW TDI Jetta Station wagon. It accepted truck nozzles and the truck lanes often were less busy mid-day than the passenger fueling areas.
One thing that folks don't recognize that may prevent a complete filling of their fuel tanks is that diesel fuel foams a lot! If you fill at a slower rate and and wait a minute before after the pump shots off you should be able to add an additional fuel. It takes a couple minutes of time but teh extra couple of gallons helps.
I try to fill the tank so it is visible in the fill hole. This is safe to do in diesels but overfilling is not recommended in gas vehicles because of evaporative canister emissions stuff.
Skyliner is offline   Reply With Quote
Old 02-28-2016, 12:04 PM   #57
Blackhat6mike's Avatar
I have a 50 gal tank/toolbox which might not work for 5ers but works well for me. It was easy to install and is much easier to remove, just 3 bolts and a worm clamp. Electric pump and filter remain attached under the bed.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 02-28-2016, 12:20 PM   #58
rattleNsmoke's Avatar
Originally Posted by Jim34RL View Post
I have been pulling into truck stops ever since I purchased my 2008 Ram Mega Cab. I am will to pay the additional cost in fuel prices for the convince of using the truck stops. If I worried about every time I purchased fuel with the 5er attached I give up the RV life style. Another point on using major truck stop fueling places is the diesel fuel is fresh do to the large turn over rate of trucks buying diesel.
Most of the time we are traveling to a destination and this could be several days away from us. So we do not un-hook the 5er and for the convince of fueling up we just pull in to the truck stops right off the interstate.
We also use two different books to find diesel fuel in states that we are not familiar with. One is called the Next Exit and the other is called the RV'ERS friend.
If you haven't done so already, or if this thread is a duplicate please bear with me. Get a Good Scam Pilot\Flying J card. It will save you .06 per gallon on diesel fuel. I don't leave home without it.
rattleNsmoke is offline   Reply With Quote
Old 02-28-2016, 01:17 PM   #59
CWSWine's Avatar
That setup should work with 5er since it sets below the rails.
Off topic but I just checked your TT on youtube, that is one classic act, unique, and well thought out floor plan. Here is the video I looked at and if I was in market for TT this would be the one hands down.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-28-2016, 01:25 PM   #60
I e used them many times. No issues at all and they really fill up the truck quickly! Otherwise, I try to find a Flying J or TA and their diesel is on the outside lanes.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
diesel
