Old 04-07-2015, 12:06 PM   #21
My old 7.3l gets 10-12 towing and around 20 when not. I may be one of the few but on my older truck I really like to use an additive. It makes a huge difference in making the engine quieter. I don't notice it help the mileage much but a smoother quieter running diesel can't be a bad thing. FWIW, my truck is tuned and modded.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 04-07-2015, 12:14 PM   #22
You might take it in and have it reflashed. Maybe it's regening too much. While I tow less weight than you I get 11.5-12.3 towing our 5er. I also get 17-18+mpg on the hwy running 55-70mph. Towing I run 55-65mph. I have a 12 2500 CTD with 3.73 gears. I realize you have the DRW version but your mpg seem a little low running empty. I can tell when the trucks in regen if I'm cruising on the freeway. If I check the EVIC for mpg it will be around 14 when in regen and then it jumps to 17+ when the regens over.
http://puredieselpower.com/dodge-pro...-egt-sims.html
http://puredieselpower.com/dodge-pro...with-bung.html
Most guys just run a code reader to delete the CEL that you MAY get.
If you're in a state that requires EPA testing then you can't do this.
You can also do a SIMs delete. Take the DPF off and replace it with a thru pipe, add the SIMs and the ECU will think you don't need a regen. MPG will increase a little. But the best part is your oil will stay brown and your OCI will go to 5000 miles+
http://www.cumminsforum.com/forum/20...e-what-do.html
goduc is offline   Reply With Quote
Old 04-07-2015, 12:16 PM   #23
TURBS's Avatar
When I had dpf on my truck it regenerated right @ 350 - 400 miles almost like clockwork
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-07-2015, 12:17 PM   #24
I have 6.7 Ford same 377FLIK and get about 10 towing 17 not towing.
2015 Siera 377FLIK
2014 Ford F350 KR
Molly the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
stevewise is offline   Reply With Quote
Old 04-07-2015, 01:00 PM   #25
jtstromsburg's Avatar
2006 GMC 3500 CC drw-empty I get 18-21 hwy. Can't wait to row with it. Don't feel too bad. With my previous f250 v10 Gasser, i got 12 empty and 4-5 towing... If I get 10 towing, I'll be ecstatic
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 04-07-2015, 01:01 PM   #26
TURBS's Avatar
Originally Posted by jtstromsburg View Post
2006 GMC 3500 CC drw-empty I get 18-21 hwy. Can't wait to Row with it. Don't feel too bad. With my previous f250 v10 Gasser, i got 12 empty and 4-5 towing... If I get 10 towing, I'll be ecstatic
You got the amphibious gmc?
TURBS
Old 04-07-2015, 01:06 PM   #27
TURBS's Avatar
Just wondering case u can't row one
TURBS
Old 04-07-2015, 01:16 PM   #28
camper1999's Avatar
Originally Posted by TURBS View Post
Tuned and modded 08 duramax.
9-10 towing 14,000 lbs.
11-12 towing 7,000 lbs
19-20 not towing
TURBS
Almost the same here:
11-12 towing 12,000
20-22 not towing highway
2011 GMC 2500HD Diesel
Old 04-07-2015, 01:42 PM   #29
about the same 2013 towing 10-12 open road 20
wire1946 is offline   Reply With Quote
Old 04-07-2015, 02:12 PM   #30
Blackhat6mike's Avatar
19-20 not towing
TURBS
X2 with TURBS
I get 12-13 towing 11,500
19-21 not towing
17-19 average around town
2013 Silverado 2500HD Duramax/Allison w/tuner. 3.73 gears
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
diesel, mileage
