Old 04-06-2015, 10:24 AM   #1
Diesel Mileage
I recently pulled a new F.R. Sierra 377FLIK with a 2012 Ram 3500 dually diesel 4x4. It has the 6.7 motor with a 3.73 rear end. Used the Andersen fifth wheel hitch, it worked great pulling the 13000 lbs. plus, trailer and load. The truck pulled great, everything went well. Except, I'm a little disappointed in the mileage I got from the trip. We traveled about 160 miles, and the truck averaged a little over 10 miles per gallon. When I travel without the trailer, I'm getting 13.5 miles per gallon on the highway. Is this the mileage that I can expect from this diesel? Is there anything I can do to increase my mileage results? I will admit, during this trip, a couple of times I pushed the throttle up to 80 mph to get by slower truckers. I'm sure that didn't help. But anyway, does anyone have any suggestions?
Rimrider23 is offline   Reply With Quote
Old 04-06-2015, 10:31 AM   #2
Fulltime family RVer
I have a 2012 Ram 3500 Dually 4x4 with 4.10 gears. I have 36,000-ish miles on the truck with 12,000+- of them being towing miles. My fifth wheel seems to be similarly sized- 42', 13' 4" tall, and weighing in around 14,000-14,500 pounds.
Your numbers are pretty close to the numbers that I tend to get. I hand calculate almost every tank (there's an app for that). When I'm estimating trip costs/budget, I plan for 9 mpg towing. My non-towing numbers range from 12-15 (though, 15 is rare) mpg depending on the kind of driving I'm doing (highway vs. around town).
I keep hearing that diesels get better mileage as they break in. It's gotten slightly better, but still lower than I'd like. I haven't played around with any ways to increase it.
Old 04-06-2015, 10:37 AM   #3
mcnabbwr's Avatar
I believe that any of the big three diesels will perform about the same. I average around 10 towing and 13-14 empty with my Ford.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 04-06-2015, 10:44 AM   #4
TURBS's Avatar
Tuned and modded 08 duramax.
9-10 towing 14,000 lbs.
11-12 towing 7,000 lbs
19-20 not towing
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-06-2015, 11:00 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
I just came down this winter from Upper Michigan to Arizona. I pulled a Wildcat 327ck that loaded is about 12,000lb with a GMC 2500 Duramax. Without the RV it gets 20-22 mpg and with the 5er I got 8-11 mpg coming down. In the stormy, windy winter travel the best I could get was 8-9mpg using a winter blend fuel. Along the way in New Mexico the mileage jumped up to 11mpg but it may have been because of the different blend fuel. My dream is 9-12 mpg when the D-max is broke in.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-06-2015, 11:04 AM   #6
[QUOTE=TURBS;827686]Tuned and modded 08 duramax.
19-20 not towing
My numbers are almost exact to Turbs,
2014 Salem 30KQBSS
2006 Chevrolet 3500 DRW Duramax EFI by ATP Trucks
Nights Camped 2015-45
Nights Camped 2014-35
bbritt18 is offline   Reply With Quote
Old 04-06-2015, 01:30 PM   #7
Tuned and modded 6.7 Cummins, 20-25 highway, 14 towing (summer fuel), 10 fully loaded to Daytona with (winter fuel additive).
If you are up north, the additive they put in the diesel to prevent gelling, will drop your mpg 2-4/gallon. I notice this even more with the car TDI.
I agree that a diesel does not really break in until you hit 100,000 miles and your mpg will get better .
Krawler is offline   Reply With Quote
Old 04-06-2015, 01:46 PM   #8
Tonkatoy77's Avatar
Mine is a 2007 Duramax tuned with EFI Live. I have a 8" lift with 36" tires. The heaviest I have towed is 8000#'s. I get 10mpg towing. Empty hwy I get 17-20, depending on the terrain. Around town I get 14-15.
I am guessing if you tuned yours and got rid of the DPF and EGR, your numbers would really increase. That is, if you can get away with it.
Tonkatoy77 is offline   Reply With Quote
Old 04-06-2015, 01:47 PM   #9
TURBS's Avatar
Op is in mo. So shouldn't be a problem
TURBS
Old 04-06-2015, 01:50 PM   #10
BombDoc's Avatar
My numbers are identical. No worries of fuel additives down here in the south.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is online now   Reply With Quote
diesel, mileage
