Old 02-26-2013, 08:39 AM   #11
Camper Less Camping
Cajun Po-Boy's Avatar
I don't know the terrain in Canada where you'll be traveling but with a gasser, you'll lose about 2% operating efficiency for every 1000' above sea level...in a diesel, you get all the power the engine is rated for up to 12000' before degradation.
Just a little extra info for you to consider if applicable...
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-26-2013, 08:44 AM   #12
Dave_Monica's Avatar
That Puma camper will have a high tongue weight for a half ton TV. The camper will probably be around 9700 lbs loaded with a tongue weight around 1260 lb (at 13%). The only half ton that you could consider would be the F150 eco with max tow and max payload options. Otherwise you're looking at a 250/2500, probably gas if you don't drive many miles daily. Everything I've read indicates that short trips and new diesel emissions aren't too compatible.
Dave
Old 02-26-2013, 08:47 AM   #13
pkurek's Avatar
Well Put On The Last 2Posts. I Agree
Paul, Dawn, Brennan & Blake Kurek
2013 Coachman 292BHDS
2005 F150 Lariat SuperCrew 4x4
1 spoiled lab and 1 even more spoiled boxer
pkurek is offline   Reply With Quote
Old 02-26-2013, 10:22 AM   #14
Dave
That camper lists a tongue weight of 879 pounds. Add 2 batteries and 2 full propane tanks and you add right at 200 pounds. Pack the camper very lightly and tongue weight won't increase much. With a dry weight of 8137, you'd be packing pretty heavy to get to 9700. Even if they don't include A/C weight, propane tanks and batteries in that figure, you're still talking about an extra 1200-1300 in weight. I know I don't have anywhere near 1200 pounds of crap in my camper. I'd say all of the food, tools, clothing, etc. in mine would weigh south of 400 pounds. I could see him being able to keep tongue weight to 1100ish, but that's still pushing it for most 1/2 tons. I'd still recommend the MaxTow Ecoboost if wanting to stay 1/2 ton gas. The F250 with 6.2 would be a good combo, as I think someone else stated.
Old 02-26-2013, 11:02 AM   #15
I used a dry weight of 8500 lbs with propane batteries etc. and 1200 lb of 'stuff' as it's a bunkhouse and therefore kids. Seeing that it's a 35' camper, I'd want the tongue weight around 13% for stability and less for the anti-sway to control.
With that tongue weight, passengers and gear, you'll be crowding the GVWR and RAWR of a F150 with max tow and GVWR of 7700 lbs. The max payload option gives you another 500 lbs capacity with a GVWR of 8200 lbs.
Dave
Old 02-26-2013, 11:23 AM   #16
Two much trailer for a 1/2 ton pickup. Pin weight will be to much. I have a 2011 F250, diesel, longbed, RWD, CC and pull a 2012 V-Cross 275 VRLS and with options like a second AC in the bedroom it is 7,791 lbs empty and ready to go almost 9,500 lbs. I would not think about pulling it with a 1/2 ton pickup. Forest River states in their adds that it is 1/2 ton towable? You will be lucky to get 10 MPG with a gasser, don't know were the 34/36 MPH came from? If you don't tow it a lot or for long distances the gasser will do and in a Ford the diesel lists for an additional $9,000 on the sticker. Good Luck
whj77372 is offline   Reply With Quote
Old 02-26-2013, 11:24 AM   #17
Wanna Be Camper
SaskCampers's Avatar
Again. Not true with the EcoBoost twin turbo
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 02-26-2013, 11:26 AM   #18
If you can swing it I'd get the Ecoboost with max ratings. The diesels pull like crazy, but there is no such thing as a free lunch, diesel = higher fuel costs, higher maintenances costs, etc. A 1/2 ton will be nicer to drive everyday as well.
Len & Cheri is offline   Reply With Quote
Old 02-26-2013, 11:56 AM   #19
Camper Less Camping
OP in original question was considering a range of gas trucks like chevy, ram, etc.. ( no mention of turbo gas engines)...with that said, my info to him is applicable...thanks though for pointing out the Ecoboost equation.
Old 03-03-2013, 10:55 PM   #20
Greenshield's Avatar
Don't overlook the possibility of getting a used diesel that is only a few years old with decent miles for less than what you would pay for a less well equipped new gasser. I had a Rockwood 8317RKSS that empty was just at my f-150 5.4 CC FX4's capacity (2007 model truck) Loaded and with the kids/gear it was white knuckle. That trailer was 6700 lbs. dry and 33 feet long. In March of 2010 I found a 2008 (on road since May 08) F250 Diesel Crew Cab SB Lariat 4X4 that had the Premium care already (still active to this day) and 25,000 miles on it. I got it for 28K out the door with a little haggle.
You could probably do similar with a 2011 at this point. even if it had 50K miles it would be worth it. We camp as much as possible and I have a long trip to work over the road. I modified mine to get @21 MPG dry and 14 towing.
Fuel is about 25 cents a gallon more, so just a quarter more over all. You will get better MPG dry and towing in the real world and the Diesel will last a lot longer. All in all cost evens out over time, but the performance will always be better with the Diesel. Leaves room for expansion too, we just upgraded to a Wildcat 344 QB and didn't have to get another vehicle. If you can do a few things mechanically yourself (change oil, fuel filters, air filters) then your costs for the diesel maintenance will be very affordable. JMHO, but I suggest a well kept 2 or 3 year old diesel.
2013 Ford F-350, FX4 ,Long Bed, 6.7 Diesel, 11500# GVW package, camper package, plow package, Electronic locking 3.73 rear end.
Husky 16K slider hitch.
New Trailer 2013 Wildcat 344QB Touring Edition with angled master bed.
Greenshield is offline   Reply With Quote
