Old 03-25-2012, 05:45 PM   #1
Great Horned Owl's Avatar
Question Diesel tow vehicle questions
Hi All,
Having never driven anything with a diesel engine, I am totally new at this. I am buying a new Palomino Puma 253-FBS, and need to get something to tow it with. The 5er is 6910 lbs. dry, and will probably max out around 9000 lbs. in use.
So far, I have determined that I want a used 3/4 ton diesel truck. The extra height of a 4x4 may cause an interference problem with the 5er, so I am only looking at two wheel drive. That greatly reduces the pool of available trucks. I am 70 years old. My current car, and most previous ones, are 5 speeds, but my wife wants auto, so auto it will be. Beyond that, I am still very confused.
Two trucks that I have found are a '08 Ford 6.4L with 70,600 miles and a '02 Dodge 5.9L with 91,400 miles. Neither are real close to home.
Much of our towing will be in mountains with steep grades. I am sure that either of them would take me up the hill with no problem, but I am somewhat concerned about descending. If I get the Dodge, I would add an exhaust brake. I just discovered that there are no exhaust brakes made for the Ford, so I would have to rely on the Tow/Haul mode to assist in the braking. Can any of you give me some idea as to how effective the Tow/Haul mode actually is?
My second question concerns fuel economy. With the larger engine and all of the additional pollution controls on the newer Ford, should I expect to see significantly better MPG on the Dodge?
One last question. Not knowing much about diesels, I would like to have it inspected. Do you have any advice on how to go about locating a competent diesel mechanic 100 to 200 miles from home?
I know this was a little long winded. Thanks for your patience.
Joel
Great Horned Owl is offline   Reply With Quote
Old 03-25-2012, 06:24 PM   #2
RattVader's Avatar
Joel glad you asked. I can't speak to what the Ford's have or do not have or the earlier model Dodge. On my '08 it comes equipped with an exhaust brake and when used in conjunction with the tow/haul mode the performance is outstanding.Big reduction in braking/speed and we especially noted it on a trip in the Pa. mountains. Obviously a great saver on brake pads. Overall would not do without it in a future truck.I even use the exhaust brake for normal everyday driving.
Steve & Sue
2011 Crusader 320RLT
2008 Dodge Ram 3500 (CTD) DRW 4x4
RattVader is offline   Reply With Quote
Old 03-25-2012, 06:43 PM   #3
Now a "Top Member"
EdJunior's Avatar
I can't say much on the Dodge, except that it will probably get much better mileage when not pulling the 5er. Pulling it, I expect it will be pretty close between the two. My '08 6.4L got around 16mpg not pulling, and between 8 and 11 mpg towing. Mostly around 9 - 10 though.
As far as the Tow/Haul mode in the Ford, it works pretty good. The only fault I saw with it was getting it out of the downshift. Sometimes the engine would really rev up before it kicked out. But it did a nice job of downshifting when needed.
I don't think the Dodge had a tow/haul that far back.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 03-25-2012, 06:57 PM   #4
No offense to the ford owners above, but chances are very high that the ford (although much newer) will not last anywhere near as long as the dodge as far as the engine goes. However, the body and interior (and probably the transmission) on the dodge will not fair anywhere near as well as the ford.
If it were me, buying used (assuming no warranty), I would stay far far away from the for 6.x no matter the year, mileage or price. I personally know quite a few people that have traded them in as soon as the warranty went out or got close due to extremely high repair costs. Our local dealer will not sell used trades with a 6.x diesel at all.
That ford will out pull that dodge (while getting worse mpg), ride better and stay looking nicer for longer, but when it has engine problems, you will have to dig very deep into your wallet to keep it on the road.
What you really need is a ford body with a cummins engine and an allison transmission! If any manufacturer could pull this off, they would own 90% of the diesel light truck market within a year.
Of course, this is all just my opinion and experience, there are some out there with a pile of miles and no problems. I personally have one of the best packages ever to roll off an assembly line- the newer stuff may outpull it, but I will be on the road a lot longer.
2010 Cherokee Grey Wolf 28BH
86ish palomino slide in
2000 F250 superduty 4x4 7.3/6speed crew/ short
edman87k5 is offline   Reply With Quote
Old 03-25-2012, 07:29 PM   #5
Ok- I would consider looking at a 2012 F150 Super Cab ecoboost with a 6.5 bed and max tow.
The turbo charger acts like a diesel in the mountains when needed.
Yes the torque is not as much as a diesel, but the turbo's will not drag you down like a normal gas engine would.
The most that 5er will come in at is just over 8000+ wet so well within the range of the F150.
The cost of the newer truck will offset the cost of diesel maintenance over the long run plus it is new!
buckeyefan is offline   Reply With Quote
Old 03-25-2012, 07:48 PM   #6
GASPEDDLER's Avatar
If you are vigilant about the maintenance on the 6.4 it will serve you well. Oil changes every 5k, filters every 10k, use a quality fuel conditioner every fill up, drain the HFCM water separator monthly. The 6.4 does not do well as a short commute daily driver. It needs to stretch its legs on the highway in order to complete regular DPF Regeneration cycles properly. Failure to allow it to complete DPF will result in repeated attempts at DPF regens and this will kill your MPG. These are the realities of today's modern diesels and apply to other makes as well. I will tell you that they tow extremely well and mine gets around 9-10 mpg towing and 11-12 mpg not towing in town. I see 14-15 on the highways which is fine considering what this truck is designed to do. The tow/haul feature works well and I tend to engage it mostly when I'm slowing her down, not so much on acceleration. The cab is the most comfortable of any vehicle I have owned with plenty of room for us plus sized guys. Good luck with your decision.
2012 F-350 4x4 King Ranch Super Duty CC 6.7 Turbo Diesel 3.55 e-locker
2011 Palomino Puma 30KFBDS with Side Paw Kitchen and Bunkhouse
Equalizer E2 Hitch
GASPEDDLER is offline   Reply With Quote
Old 03-25-2012, 07:51 PM   #7
Stevea1956's Avatar
I was told that the tow/haul only delays the shift points when engaged. If that's true, it won't make any difference when going down a grade.
I have an exhaust brake on my Dodge and highly recommend them, especially if you're going to be towing in the mountains. I've come down 6% grades towing a 15,000 pound 5th wheel and never had to touch the brakes.
The older diesel engines, like in the Dodge you are considering, are noisy but they get decent fuel mileage, are just about bullet proof and 90,000 miles is just broken in according to some old diesel guys.
If I were to choose between the two trucks, I'd probably take the Dodge and add the exhaust brake.
As far as getting it checked out, call a local Ram dealership and ask them if they can look at it or recommend someone that can. You can take the opportunity to inquire about adding the exhaust brake while you're there.
Steve & Lauren
2011 Windjammer 3065W
2012 Ram 3500, 6.7 Cummins
Stevea1956 is offline   Reply With Quote
Old 03-25-2012, 07:59 PM   #8
On the Fords when you apply the brake it will down shift to use the engine's braking HP's
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
https://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 03-25-2012, 08:17 PM   #9
Now a "Top Member"
EdJunior's Avatar
Someone told you wrong. When in tow/haul mode, when you apply the brake, the truck will downshift accordingly. In my '08, the first time it did it, it kinda took me by surprise. It was a pretty hard downshift. In my 2011, it is a much smoother process. Really nice and works great.
Like was said above, if you take care of the '08, and are diligent with the maintenance, it will do you good. I really liked my '08, but had a chance to get in the new 6.7L and I took it.
Ed and Sharon
2010 Wildcat 28RKBS
Retired AF MSgt
Old 03-25-2012, 08:31 PM   #10
No matter what, don't get a diesel that has been chipped. I use the Tow/Haul feature for going down grades and it works great with a 13k + 5er pushing you down the hill.
Ed & Laureen
2005 F-250 4X4 SD 6.0 Powerstroke
2009 Cherokee Wolf Pack 285wp (the side door ramp toy hauler)
nailit is offline   Reply With Quote
Old 03-25-2012, 08:36 PM   #11
M109Rrider's Avatar
On the older Dodge's tow haul holds gears longer on the up shifts. It also will allow the torque converter to lock in both 3rd and 4 gear (vice only 4th). It will downshift sooner while slowing but only to match gears to road speed. Due to the lack of intake vacuum diesel's don't engine brake naturally like gas engines. It is very easy to over speed a diesel while downshifting if its not equipt with an engine or exhaust brake.
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 03-25-2012, 08:42 PM   #12
With the price of used 3/4 ton trucks you can buy a 1 ton dually for about the same money. The dually really helps pulling a 5th wheel when the winds are bad. Most of the newer diesels have engine brakes on them. The chevy that we use (its my mother in laws truck)has the engine brake that engages when the speed control is on. when the truck goes downhill the engine brake kicks in. duallys are more stable just gotta be careful with the outside wheels. just my 2 cents..
imabmwnut is offline   Reply With Quote
Old 03-25-2012, 09:13 PM   #13
jimh's Avatar
i would check the clearance of the 3/4 between bed and trailer. my first trailer rode too close to the bed and i did hit it a couple times.
when buying used, check the maintaince. i would make sure the oil was changed timely and the radiator maintaince was performed when required. one problem diesel engines have is pin holes in the cyclender walls due to cavation. there is a additive for this. my 2002 used a gold anti freeze that requires change out every 100000 (it had the addative in it). i don't believe this is unique to Ford. Ford talks abt it in the owners manual. they put it in a kind of sugar coated terms.
i did loose an engine on a 92 and received a notice 2 mos after i replaced it. ford said they had experienced a few premature failures due to poor radiator maintenance.
my 2002 had its first maintenance problem last summer; the alternator went out. now i have porblem #2, the starter selanoid needs replacing ($30). i have abt 150000 on it.
personally, i would stay away form one that has been reprogrammed. but that is just me.
jimh is offline   Reply With Quote
Old 03-25-2012, 09:23 PM   #14
cheese53073's Avatar
my 06 Ram 2500 CTD 4x4 gets 23 mpg empty and 15 towing my rockwood 8293rkss fully loaded. this is with 2 adults and a bed full of firewood.
Rockwood 8293RKSS
cheese53073 is offline   Reply With Quote
Old 03-25-2012, 09:55 PM   #15
Toby's Avatar
I would stay clear of any 6.x diesel Ford. They require a lot of maintenance and buying a used one (IMHO) means you need one that the PO did maintenance properly. The market has tons of 6.x diesels out there for this reason. Get the older 7 l engine and you'll be fine.
I researched the crap out of the 6.x and also tried to be a 3/4 gasser but nobody is trading these in, in good condition. At least around here. I ended up spending an extra 10K more (than I wanted to) and got a brand new EB F-150 with the max tow for around 26K (after trade). 9K can be handled by that truck but it's into the upper range of it's capabilities.
Good Luck!
Toby is offline   Reply With Quote
Old 03-25-2012, 10:16 PM   #16
Bill_C's Avatar
I don't have a chip, but I did get a programmer. It has put my 3500 to 25 mpg, decreased the oil change frequency to 12,000km. At the same time I did not increase horse power, just improved injector timing.
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 03-25-2012, 11:10 PM   #17
BOBFIDY's Avatar
Not sure of earlier model Fords...but my 2011 F350 Dually in tow/haul mode really works great helping to slow down the rig in the hills. The first time it really worked for me was going south out of Springfield, MO going to Branson. There are some really good hills there and we never felt any discomfort at all in maintaining control of the rig.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 03-26-2012, 06:04 AM   #18
Oakman's Avatar
I agree with BOBFIDY, the tow/haul mode on the Ford works great on steep grades. It's very easy to control the speed of the truck going downhill.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 03-26-2012, 07:16 AM   #19
sure do like the way my 2008 dodge cummings tows my wildcat 31TS exaust brake and 6 speed automatic. I have always been a CMC person, however cummings does a great job
Denny in Los Lunas is offline   Reply With Quote
Old 03-26-2012, 08:45 PM   #20
Toby's Avatar
Holy Cow! No kidding! Those are some very steep hills. There's another one in Branson around the corner from the old amusement park too. Just thought I'd say that.
