Old 09-12-2013, 12:13 AM   #1
simplyrwc's Avatar
Difference between hitch ball?
A lot of hitch balls are round. Some are cut off at the top. What's the difference and are they interchangeable?
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 09-12-2013, 12:15 AM   #2
simplyrwc's Avatar
Ok I'm probably really showing my ignorance here but if you don't know ask right?
2013 Days Camped 14
Old 09-12-2013, 02:43 AM   #3
raspivey's Avatar
I've never seen any marks on the very top of a completely round ball, so I'm assuming that the top of the ball doesn't make much contact on most couplers. I didn't find any references to a difference when I searched online for it either. I would have to say, in all likelihood, there's no difference at all.
Old 09-12-2013, 07:53 AM   #4
The most contact bearing area on a (RV)type ball socket is (50%). If the ball is machined with a flat surface on top (normaly where info is stamped,1-7/8-2-5/16 and Lbs) the bearing area is reduced more. There are some (Self Lube balls that use the flat top area for a Teflon? lube insert, Also there are (Bulldog type Sockets that (Clamp) around a ball that would allow more cotact area. Youroo!!
youroo is online now   Reply With Quote
Old 09-12-2013, 07:55 AM   #5
It took this time! Thanks Eppydad! Youroo
Old 09-13-2013, 10:33 AM   #6
simplyrwc's Avatar
Ok thanks....wanted to ensure I wasn't towing with the wrong ball for my hitch. I am trusting my dealers service department less and less each day and am grateful to have FRF as a go to!
2013 Days Camped 14
