Old 07-22-2016, 08:04 PM   #21
friendofacatahoula's Avatar
Originally Posted by spock123 View Post
I had a 08 2500 diesel and no exhaust brake but you could set the cruise and put truck in tow/haul and truck would act like it had a exhaust brake. As a matter of fact you can do the same with a 2500 gas burner and I think with a 1500, Silverado of course
A 6.0 gas vortec in a 2500 is not going to act like it has an exhaust brake. Doesn't matter if it's In tow haul, with cruise set, however you set it unless you have a turbo added The motor will no get compression braking from the exhaust. The tranny will down shift, and the 6 speed does it better than the old 4 speed but it just revs higher. I would not call it "braking". The 6.2 and 5.3 won't either.
In 08 the diesels did have VGT's on the turbos hence the cruise function acting like a modern exhaust brake and you could even have customs tunes that gave you exhaust braking.
2015 MiniLite 2109S
2016 Ram 3500 6.7
friendofacatahoula is online now   Reply With Quote
Old 07-22-2016, 09:19 PM   #22
Kenny kustom's Avatar
Originally Posted by Handydc View Post
Wait a minute. You turn on exhaust brake and leave it on when towing?? You don't just turn it on when you want to help you slowdown as in going down steep hills.
Mine is on towing or not.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Kenny kustom is online now   Reply With Quote
Old 07-22-2016, 09:21 PM   #23
BandJCarm's Avatar
My book says that the exhaust brake makes the tow haul shifting points "more aggressive".
Both are on the minute I hook up, and stay that way until I unhook.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-22-2016, 09:35 PM   #24
Mine being a 2007 with a flapper type exhust brake it will freeze up if not used from time to time
railroaderone is offline   Reply With Quote
Old 07-22-2016, 09:41 PM   #25
Difference in braking between Exhaust Brake and Tow/Haul Mode?
Any of the 07's I have seen do not have a flapper. They have a gear driven sliding ring.
Being that it's been awhile since I have seen one though I went and searched it to make sure and the 07.5-08 have that style. Yes I can understand soot in those early 6.7 could be an issue when not hauling.
My neighbor has an 07 but it has an aftermarket pacbrake I believe is the brand. No Oem.
Anyhow. The same holds true, run it whenever you tow or whenever you feel additional braking is beneficial.
2015 MiniLite 2109S
2016 Ram 3500 6.7
Old 07-22-2016, 11:32 PM   #26
mekkerlc's Avatar
Thank you everyone for the input! Part of the reason for this post was to make sure my exhaust brake is working and doing what it's supposed to. I guess it is...and my initial thought of it needing to sound like the tractor trailers do is a bit unrealistic.
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
mekkerlc is online now   Reply With Quote
Old 07-23-2016, 12:12 AM   #27
Hutch333id's Avatar
Thanks people. I have learnt something new here tonight. I didn't realize I could drive the truck with the exhaust brake always on while towing. I have normally had it in the tow/haul made but only ever engaged the exhaust brake as I've crested the top of the hill and just about to start my decent. I have a long trip coming up in the next couple of weeks taking me over the Rockies. After reading the previous posts I shall now be switching the EB and TH on as soon as I fire her up and leave home.
Much appreciated.
Richard & Diane
2014 Cedar Creek 38FL
2016 F350 Lariat CC DRW
Retired Metropolitan Police (UK)
Hutch333id is offline   Reply With Quote
Old 07-23-2016, 06:24 AM   #28
Originally Posted by PSU Turf View Post
A Duramax exhaust brake is not designed to make noise like you hear on a Kenworth. The Duramax runs much more quiet than Cummins or Powerstroke and that carries over to the exhaust brake. I always engage tow / haul and exhaust brake when towing. The stopping power with this setup is incredible compared to any other pickup truck I have driven.
Ditto^^^
When the exhaust brake is engaged, I will see reverse boost on my Edge gauge. It will show upwards of 12-14psi of boost being blocked or restricted, however it works. As the reverse boost is going up the truck is slowing more. on hills you don't even have to touch your brakes. I always use both when towing.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 10 so far
DocGTO is offline   Reply With Quote
Old 07-23-2016, 08:53 AM   #29
Exhaust brake is to get braking assist from the engine. Tow/haul mode uses the transmission for braking assets. Use either, or both.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 07-23-2016, 10:24 AM   #30
I'm another full time user of tow\haul and exhaust brake anytime my trailer is hooked up. You may not hear the exhaust brake, but you'll sure as heck feel a difference in stopping compared to when it's off.
2014 Chevy 2500 CC, Duramax
2017 Wolf Pack 25pack12 Toyhauler
polishdon is offline   Reply With Quote
modifications
