Old 01-29-2013, 11:23 AM   #1
Swaggler's Avatar
DirecLink?
I am negotiating with the Forest River dealer a new 21WRS V- Lite. The unit weighs about 6,600 lbs. fully loaded (according to spec sheet). I am considering the DirecLink brake controller but don't know if it is worth the extra cost. Is anyone using a DirecLink brake controller? Would this be overkill for a smaller trailer like the 21?
Brakes are one area where i don't want to cut corners.
I appreciate any comments from anyone who has some experience with these things.
Thanks.
Always believe that you will ultimately succeed at whatever you do, and never forget the value of persistence, discipline, and determination.
Swaggler is offline   Reply With Quote
Old 01-29-2013, 01:08 PM   #2
Swaggler's Avatar
Ok. I didn't see the previous thread on brake controller recommendations. Looks like P2's are the controller of choice.
Old 01-29-2013, 03:45 PM   #3
Thanks.
If you enter "brake controller" in the search box below the header marked "search" and check the FRF (Forest River Forum ) option then click the search button next to it , you WILL get about a MILLION (actually 14 pages) posts about brake controllers ! Jim
FarmerJim is offline   Reply With Quote
Old 02-02-2013, 08:18 PM   #4
Plug It Right
We have used the Max Brake for over 4 years and absolutely love it. It stops us like a dream. Hugs, Di
2014 Ram Dually Pickup, Tailgate Easylift, Do More Slide Step & AMP side steps
1996/2010 Triple Slide Carriage, Mor/Ryde Suspension, Kodiak Disc Brakes, Big Foot Automatic Leveling System, TST Tire Pressure Monitoring System, Plug It Right Stabilizers.http://www.plugitright.com/5thwheelREDO.html
Dutch & Di is offline   Reply With Quote
Old 02-03-2013, 09:11 AM   #5
Swaggler's Avatar
Thanks. I visited the website...This looks like a good solution. Did your dealer do the install, or did you install it yourself? If so, any issues or problems? I'm also curious about how well does the manual override work?
Thanks.
