Old 10-17-2015, 01:52 PM   #11
Left Coast
Do you have leaf springs? 2 wheel or 4?
Old 10-17-2015, 02:00 PM   #12
Ford Idaho's Avatar
When fully loaded the lite rides nose high, lowering the truck is not an option.
One thing I am looking at is a shorter hitch, I like the one I have but feel it is just to tall.
I have over six inches between the rails and the bottom of the trailer.
Old 10-17-2015, 02:01 PM   #13
Left Coast
Why can't you lower truck?
Old 10-17-2015, 02:12 PM   #14
Left Coast
I'd give you a 16000 'Lil rocker hitch' , less rails. Can't raise pin-box? When I went to slider, I raised pin-box, and pulled out rear axle spacer blocks, then lowered front of 'barney'.
Old 10-17-2015, 02:13 PM   #15
Ford Idaho's Avatar
I could but I am not a fan of low rider 4X trucks.
I looked at removing the rear springs and replacing it with air but the cost and work involved is quite extensive.
Old 10-17-2015, 02:14 PM   #16
Ford Idaho's Avatar
No pin is all the way up.
Old 10-17-2015, 02:18 PM   #17
Left Coast
Mine went down 3" and now looks like the tires fit the openings better....still have the 4x4 look and view.
Old 10-17-2015, 02:26 PM   #18
Mine has just over 5" of clearance between bed rail and 5er and I have had no issues at all. I have been over some pretty uneven spots in my travels around MT, ID, WA and OR.
I don't know if it makes any difference if short bed (mine) or long bed or because we have a Reese Revolution pinbox.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is online now   Reply With Quote
Old 10-17-2015, 02:29 PM   #19
Left Coast
Pinbox
Old 10-17-2015, 05:40 PM   #20
Trifold covers
Tri fold covers can bite you big time. I was very low on fuel in a bad place. The only station required a hard right turn up a slight incline. The latching mechanism on top of the stacked trifold punched a couple of holes in the underside of the overhang on my fifth wheel and bent the latch beyond use. I now use a roll top so nothing stickes up above the truck rails.
dwebster is offline   Reply With Quote
5th wheel, truck, wheel
