Old 10-17-2015, 08:41 AM   #1
Fred H.'s Avatar
Distance between truck rails and 5th. wheel
Being a new 5th. wheel owner, I just took for granted that the dealer set up my hitch for the proper height to tow my 5th. wheel.
Reading other threads, I've noticed that not only is it ideal to have the trailer being towed level, but you need to have a minimum of so many inches between the bed rails and bottom of the 5'ers overhang.
So my question to the experts who have towed their 5'ers. is this. Is there a "sweet spot" in inches that I should be looking at for best performance and with no fear of bottoming out when pulling into fuel stations that might have a steeper than normal entrance?
I also have a tri-fold cover that is toward the front of the bed when towing. When folded is about 3 inches thick. I don't believe this will be a problem however.
Thanks in advance for all the education I'm expecting to receive.
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 10-17-2015, 08:56 AM   #2
clr
You are correct the 5th wheel should set level when connected in the tow position. You should have 6 inches between the bed rails and the bottom of the 5th wheel. I would not feel comfortable with any less than 5 inches. I would not think that having the fold up cover in front of the hitch as you described would be any problem with most 5th wheels.
clr is offline   Reply With Quote
Old 10-17-2015, 11:03 AM   #3
I have to have about seven inches of clearance to keep my cap from touching my tri fold in those funky driveways, trailer is couple inches nose high to achieve that
jerky is offline   Reply With Quote
Old 10-17-2015, 11:16 AM   #4
Witch Doctor's Avatar
X'2 on 6" clearance..........
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-17-2015, 11:44 AM   #5
Left Coast
Why not lower truck? Trailer axles and tires would thank you.
Old 10-17-2015, 12:57 PM   #6
CWSWine's Avatar
I had tri-fold cover on my last truck and yes the 5er did hit it while backing up into camp site. I was running about 6 1/2 clearance from the bed rails but the tri-fold was about 3 1/2 inches thick when folded.
On my current truck I have soft cover and I run about 5 1/2 clearance which I thinks is fine for normal road conditions but we do watch it really close when backing into the camp site or pulling into driveways.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 10-17-2015, 01:14 PM   #7
Anders's Avatar
We have 6" on our rig. Would not go any less. When boarding and exiting ferries (we live on a small island) it get down to 1 inches at times by the tailgate. Also some back country roads with with pointy small hills (truck is over the hill going down while trailer still on its way up) can be close calls
Cheers
Anders Cortes Island, BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab Chuckwagon: 2011 Rockwood 8265WS
My First RV Cookbook Coming Soon
Travel Blog
Cooking Blog
Anders is offline   Reply With Quote
Old 10-17-2015, 01:29 PM   #8
Truck should be level too. Air bags solve this. Most hitches and trailer pin boxes have vertical adjustment Also trailer height can be adjusted at axles but requires welding spacers to spring mounts.
Harkerr is offline   Reply With Quote
Old 10-17-2015, 02:10 PM   #9
I have been looking for ways to lower the rear of my truck. So far no luck finding a way that makes enough difference to matter. Would be great if truck set level... now it is tail high and putting 3,000 lbs of pin weight on it drops the top of the tailgate only 1/2 inch. I have a 2015 Chevy 3500HD Diesel 4X4 crew cab long bed. If anyone has suggestions, approaches/parts, would love to hear them.
PapaE is offline   Reply With Quote
Old 10-17-2015, 02:12 PM   #10
Do you take some of the springs out (to get the tail of the truck down) when you put in air bags? Any recommendations on what manufacturer of air bags?
5th wheel, truck, wheel
