Old 08-25-2016, 07:47 AM   #1
Komodo's Avatar
Do I add sway bars to my F-150?
I’m purchasing a 2016 Ford F-150 this week. It comes with integrated sway control. On my jeep I had the sway bars added to my hitch system. Does this mean that when I use my F-150, I don’t add the sway bars anymore?
This is what the brochure says,
“Trailer Sway Control – works in conjunction with the AdvanceTrac® with RSC® (Roll Stability Control™) system to expand the vehicles dynamic stability control capabilities, adding an additional layer of confidence and control while towing a trailer”
I’m pulling a four thousand pound camper. Rockwood HW277
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. Wolfgang Riebe
Komodo is offline   Reply With Quote
Old 08-25-2016, 07:54 AM   #2
Prime Member
An integrated sway system like you mention helps your truck control a swaying trailer. A sway bar reduces or stops your trailer from swaying in the first place.
Get the sway bar.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 08-25-2016, 08:22 AM   #3
Swaggler's Avatar
I reccomend using the sway bars with the hitch as well. I am not familiar with Fords anti-sway system for the F-150 but am guessing that it would be working overtime without the sway bars on the hitch.
Always believe that you will ultimately succeed at whatever you do, and never forget the value of persistence, discipline, and determination.
Swaggler is offline   Reply With Quote
Old 08-25-2016, 09:56 AM   #4
I go RV'ing not Camping
jgourlie's Avatar
Sway bars are a must with any half ton pickup
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 08-25-2016, 10:08 AM   #5
ben31's Avatar
An anti-sway bar if faily cheap (not talking about the integrated Weight Distribution Hitch that also takes care of swaying), and they are easy to put on and take off. I would use it, just to keep the trailer from sawying much in the first place. When you get trucks flying by you, you will appreciate that anti-sway bar! You may even get off and tighten it some more!
Really, you will appreciate having it, where if you didn't you'd have white knuckles in no time.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 08-25-2016, 10:57 AM   #6
Another urban myth rears it's head.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is online now   Reply With Quote
Old 08-25-2016, 11:07 AM   #7
A need for a sway bar has more to do with trailer size/length and weight... in addition to TV size.
I have an F250, haul a 38' 11k lbs TT and have a WD system with integrated sway control. I also use a sway bar and consider it mandatory based on my experience with and without it.
Different trailers and WD system combinations may require one and may not require one.
The TV is just one factor.
325BH is offline   Reply With Quote
Old 08-25-2016, 11:07 AM   #8
dbarr's Avatar
Yep. Pulling the same trailer with my 150 as I did with my 350. Needed sway control then just as much as I need it now.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2019-8, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....54
dbarr is offline   Reply With Quote
Old 08-25-2016, 11:29 AM   #9
jgourlie's Avatar
I didn't look close enough to the trailer the OP is pulling.
It isn't a full size trailer so Sway Bars may not be necessary with a tongue weight of only 400lbs. So yes it would depend on if the OP is getting any squat on his F150. If it were me I would still use a Weight Distributing Hitch with 600lbs "Sway Bars" because you can never be too safe.
So I respectfully change my statement to weight distributing hitch/sway bars are a must for any half ton with a full size trailer.
Old 08-25-2016, 12:06 PM   #10
I recommend a WDH with integral sway control. There are many that operate just fine without a separate sway bar. My BlueOx SwayPro has served me very well and is highly recommonded, IMHO.
Don't count on the truck's anti-sway system alone...stop sway before it begins...and distribute the tongue weight appropriately at the same time.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
sway
