Old 04-13-2015, 10:17 AM   #11
thebrakeman's Avatar
Oh...I just saw you have a 2.5" receiver. That very well may be 1800 lbs WC. I don't know. You should confirm. But either way, I'd go with the WDH, especially since you already have it.
thebrakeman is offline   Reply With Quote
Old 04-13-2015, 10:21 AM   #12
I bought the same rig and will use the WDH for any long hauls I do, but for a quick 90 minutes trip, i find I don't need them. I did set up my hitch to use them though, if for no other reason then the Sway control attachement.
I also realized that the 2500 has integrated sway control this weekend, but will still always put the bar on for that
2015 Ram 2500 4x4 6.4l with 2015 Flagstaff 21FBRS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 04-13-2015, 10:48 AM   #13
Originally Posted by Crockett View Post
WD reduces porpoising where the front bounces over bumps.
That was my experience.
fvstringpicker is offline   Reply With Quote
Old 04-14-2015, 01:22 PM   #14
Do I even need WD bars now?
Never had em so don't have any experience with them. My TV is a 2000 F350 4door long bed. Initially I towed my ulsbs275 with a tongue weight of around 2000lbs on the hitch that came with the truck and except for one windy day had no issues. Then I discovered the factory hitch was rated at 500 lbs TW and 5000lbs Tow 8-O I upgraded to a new hitch rated for 2550 TW and 17,000 tow. Truck n Trailer are level even with the Airbags at 5psi, but for hi way driving I keep the bags at 60-65psi and the cruise control at 65mph. Smooth sailing thus far.
rblack22 is offline   Reply With Quote
Old 04-14-2015, 02:42 PM   #15
Crockett's Avatar
smooth sailin' I guess...thats a friggin' land yacht. Longer the wheel base, the less imperative the WD. Why?...less mechanical advantage on the front end by the Tongue Weight
Crockett is offline   Reply With Quote
Old 04-14-2015, 07:48 PM   #16
I guess I will try a short pull to see how it rides. I do have two sway bars that I can use to control sway if it needs it
Skippy38 is offline   Reply With Quote
