Old 06-26-2014, 07:37 AM   #21
MtnGuy's Avatar
Just in case a new member is seeing this thread, the comments are in jest. They are, aren't they ??
Old 06-27-2014, 06:05 AM   #22
Incheon, S. Korea
BigBaron's Avatar
In jest? You'd put that trailer in the back of the bed instead of towing it, wouldn't you?
Me, Julie, Lil' Barry, Faith, and OSD Fang
2012 Coachmen Clipper 126 - Don't even have a TV anymore.
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 06-27-2014, 10:06 PM   #23
asquared's Avatar
You might be able to pull that trailer, but do you have enough truck to stop it?
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 06-27-2014, 10:52 PM   #24
SKnight's Avatar
You're exceeding 25% of the trucks towing capacity, I'd look into stepping up to a HDT ASAP, Volvo makes a nice tractor.
And if you don't, you better pray that when you barrel roll that overloaded thing it's not near my family.
At least step up to 3000lb airbags, upgraded brakes and suspension, 19.5" MDT tire/wheel combination, real trucker sun visor, CB radio, HID headlamps to warn people as you approach, then get it all approved by the DOT to see if they'll let you haul that monster on public roads.
Old 06-28-2014, 04:55 AM   #25
Incheon, S. Korea
BigBaron's Avatar
SKnight - do you really think he needs the 3000 lb bags? 2000 should be enough...
Old 06-28-2014, 05:22 AM   #26
Ford Idaho's Avatar
He would have to air the bags to nearly psi capacity with that a blown bag is possible and loss of control at city street speeds would be ugly.
The 3000 lb bags would allow him to keep the air pressure a little under max without bending the springs.
Old 06-28-2014, 06:05 AM   #27
Platokidd's Avatar
Originally Posted by N3HCP View Post
Sometime we just need a little levity. The camper weighs a whole 3500 pounds and the truck is a Ford F-350 dually. We use the Clipper for short or out of the way trips where the big fiver is a bit much.
We do get some comments from fellow campers in the campgrounds.
That ain't right
2014 LaCrosse 323RST-TE-C
2009 Chevy 2500HD Z71
Seasonal
Zelda the campin dog
Old 06-28-2014, 07:18 AM   #28
KDHfan's Avatar
Let me guess... The salesman said "You can tow that camper, no problem." ???
There's a tow calculator on here somewhere to check your numbers. Please be safe.
2014 Rockwood 2306 w/Murphy Bed
2014 Toyota Tundra 5.7L CrewMax
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 06-28-2014, 07:49 AM   #29
SKnight's Avatar
Oh yeah, you say that from the safety of South Korea, meanwhile over here we're stuck with that death trap.
Old 06-28-2014, 08:09 AM   #30
Incheon, S. Korea
BigBaron's Avatar
The safety of South Korea?
There isn't a Korean word for "safety".
P.s. We were both wrong. The trailer weighs 3,500 lbs. Have to get the 4000 lb bags... :P
Old 06-28-2014, 08:17 AM   #31
Ford Idaho's Avatar
Nah, a ton it on the trailer axles, which makes me wonder is some kind of extra support on the trailer it's self is needed.
Perhaps a Timbren kit?
Old 06-28-2014, 08:18 AM   #32
SKnight's Avatar
Sure there is, it's called "Abandon ship" and "RUN!!!"
But yeah, 4K bags for sure.
Old 06-28-2014, 10:27 AM   #33
asquared's Avatar
I think an axle flip is in order. I think you also need to increase your tongue weight. And make sure you switch those trailer tires out for some E rated LT tires as those are obviously overloaded.
2014 Sabre 34REQS-6
Old 06-28-2014, 10:32 AM   #34
so you started with the right tow vehicle and will be trading the camper in later?
bob34787 is offline   Reply With Quote
Old 06-29-2014, 12:32 AM   #35
Incheon, S. Korea
BigBaron's Avatar
Naw, he is piddling around with a DRW instead of getting an HDT. Oh well, it's his money.
Old 06-29-2014, 08:39 AM   #36
Originally Posted by Arefbee View Post
I have talked about it too. DW just smiled and shook her head. I think I heard her say "12 step RV program"...
Tried it...doesn't work!!
2020 Flagstaff 26FKBS pulled by a 2019 F-350 Diesel
N3HCP is offline   Reply With Quote
Old 06-29-2014, 08:46 AM   #37
If you think this setup is bad, how about this?? This is the A-liner we traded in on the Clipper last year. We used the A-liner because of the terrible roads in the part of Canada we were visiting. The bumps were so bad that the A-liner actually bent in the middle!! When we got back to the States we couldn't open the door without a hammer to pound it out of the door jam.
Old 06-29-2014, 09:10 AM   #38
Incheon, S. Korea
BigBaron's Avatar
See! Even a small A-Liner was unsafe due to suspension issues!
YOU NEED THE 4000 lb BAGS!
And another thing - a 12-step program won't work with RVitis because most RVs have only one or two steps at the entry. (rimshot)
truck
