Old 04-21-2015, 02:44 PM   #1
Do I need a diesel?
Hi all, we just took delivery of a 2016 Sandpiper 371 REBH, and I currently have a 2012 F250 with the 6.2L. It has a max tow cap of 15,500 and right now my trailer weighs about 13,500 lbs. it has no issues towing like excessive high revs, but I personally want the warm fuzzy of having a diesel. But do I absolutely need one? They're expensive and if I'm fine with the gas then I'll stick with it.
Jsabe07 is offline   Reply With Quote
Old 04-21-2015, 02:46 PM   #2
TURBS's Avatar
13,500 loaded or dry weight?
What's the ccc of the truck your looking at?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-21-2015, 02:46 PM   #3
Ford Idaho's Avatar
You do not "need" a diesel, but I think you would like it.
Old 04-21-2015, 02:55 PM   #4
What's the GVWR of your TV? That's what you should worry about. What will your 5er weigh when loaded? I have a diesel TV and have had 2 diesels since 2001. The latest is a 2011 GMC, 1 ton dually, 4x4, long box, crew cab. It pulls my 35 ft 5er with no problems. It also carries the weight of a 6o gal. fresh water tank full along with a 50 gallon fresh water tank, full, along with a 50 gal. aux fuel tank in front of the 5th wheel. I'm under the GVWR when I weigh 23,900 lbs TV & 5er, going boondocking. So it's something for you to chew on and then come up with a decision. Oh yes, I would say that my fuel mileage is fair at between 9.5 -13 mpg, depending on terrain and wind.
Pipeman is offline   Reply With Quote
Old 04-21-2015, 02:55 PM   #5
13,500 is the loaded weight with what we have in it now. The truck I'm looking at has a 16,400 lbs cap. I know it's only 900 lbs, but it's the fact of having the turbo.
Old 04-21-2015, 02:58 PM   #6
TURBS's Avatar
I pulled my 14,000 lb sabre for one year with a 3/4 ton gas and said enough.
Duramax diesel coming up.
I'm glad I did it! No regrets!
TURBS
Old 04-21-2015, 03:02 PM   #7
Gvwr for mine is 10,000 lbs.
Old 04-21-2015, 03:15 PM   #8
Mine is around 13,000 lbs The 4x4 takes some GVWR away but I do use it
Old 04-21-2015, 04:00 PM   #9
thebrakeman's Avatar
You are OK with weight. 12,500 dry, 13,500 current loaded. 15,500 max tow rating. As long as you are not exceeding payload or rear GAWR ratings, then love the one you're with.
I would think, the more you tow, the more you would appreciate a diesel. Full timers, or those that take long trips every year.
thebrakeman is offline   Reply With Quote
Old 04-21-2015, 05:11 PM   #10
Computer Nerd's Avatar
You will love a diesel and never look back.
Computer Nerd
2014 Chevy Silverado 3500 HD Duramax
2016 Sandpiper 35ROK
Computer Nerd is offline   Reply With Quote
diesel
