Old 04-15-2013, 10:26 PM   #1
Do I need a slider 5th wheel?
I'm looking to purchase a new 2011 Cedar Creek 36RE, my tow vehicle is a 2011 F350 Diesel Crew Cab short box (6.5'). I can't find any literature on whether the 36RE in 2011 has a design for not requiring a slider 5th wheel on these shorter truck boxes?
Can anyone help?
djkarau is offline   Reply With Quote
Old 04-15-2013, 10:33 PM   #2
Phat Phrog Stunt Crew
mackman1994's Avatar
You don't really need a slide hitch for any fifth wheel. The only thing is that you will be very limited on your turnin radius on some models. So with a short bed I wouldn't be without a slide hitch.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
Old 04-15-2013, 11:03 PM   #3
Denver, CO
garbonz's Avatar
If it doesn't say 88deg designed or short bed trucks than assume it isn't, and go with a slider. The short bed designs have a pronounced dimple on the front corners or an extended pin box. It doesn't look like yours does. AND there are lots of slider options and even kingpin mods, so lots of variety.
2017 Fuse 23T
Old 04-16-2013, 01:47 AM   #4
puff's Avatar
Owning a 2011 36RE....go for the slider hitch. I was talking with a guy last weekend who has a short box and already has 2 dents in the cab from tight turns. Most times you won't need it but those few you will be glad you bought it..!
If you have any other questions about the 36RE just ask, I hope I can help..! If not someone here can..!
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 04-16-2013, 07:16 AM   #5
Now a "Top Member"
EdJunior's Avatar
Even if it says it was designed for short beds, there's this little thing called Peace of Mind. You will feel better having it and not needing it, than you will needing it, and not having it.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Retired AF MSgt
Old 04-16-2013, 07:30 AM   #6
A Reese Sidewinder hitchpin eliminates the need for a slider on short bed trucks by pivoting the trailer 22" back. It also allows for over 90° turns. Works great.
Old 04-16-2013, 07:38 AM   #7
TURBS's Avatar
More than one way to skin a cat, but both ways get the job done.
Old 04-16-2013, 07:46 AM   #8
Oakman's Avatar
NO! You don't need a slider hitch for a 2011 Silverback. The dramatic front cap design that was introduced in '09 or '10 allows for a 90+ degree turn. When I owned a 2008 Wildcat I used my slider all the time. Since buying the Silverback over a year ago I haven't used it once.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-16-2013, 07:47 AM   #9
camper1999's Avatar
Only take advice from anyone that has your truck and trailer combination. Some short beds are not 6.5 feet and that makes a difference. Some trailers the nose is cut differently. I do not have that combination but my two cents is people I have talked with before buying my trailer, anyone with a 6.5 bed never used their slider even though they were told they would need one.
2011 GMC 2500HD Diesel
Old 04-16-2013, 07:47 AM   #10
tugboat369's Avatar
I put A PullRight in my bed it is automatic will slide back 14" and don;t have to get out of the truck or think about it. It is also removable by pulling 4 pins. But it is heavy have a hoist in my garage it lift out. They are expensive but worth the peace of mind.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 04-16-2013, 07:48 AM   #11
camper1999's Avatar
X2
Old 04-16-2013, 01:36 PM   #12
Denver, CO
garbonz's Avatar
Yours specifically says 90 deg, does his? The one's I saw on the web with OC model number did NOT have the dimple. So be careful what you recommend.
2017 Fuse 23T
Old 04-16-2013, 03:14 PM   #13
Oakman's Avatar
You are absolutely correct garbonz. My mistake and I stand corrected. Somehow I read that post as a Silverback and not a Cedar Creek. The Creeks don't have that radical front cap. I don't know if a slider hitch would be required for his model. My bad and I apologize.
Apparently I'm getting quite goofy in my old age.
Bob and Joyce
ATU Local 788
Old 04-16-2013, 05:08 PM   #14
Thanks everyone for your input...I just got word back from the dealer that the user manual does indeed state that it is a 88 degree front cap design. The other nice thing with the 2011 and newer F350's is that the box is 6'9" so it gives you a little more "piece of mind" than the standard 6'6" box from Dodge and Chevy. As well, as this unit has the Trail Aire pinbox, which is 5-6" longer than the traditional pinbox and therefore pushes the trailer back away from the cab quite a bit.
Old 04-17-2013, 01:28 PM   #15
Thumbs up Off set Hitch
I use my Chevy 2500 DMX (6.5 box) to pull a gooseneck horse trailer so I installed an off set goose neck converversion on the king pin and killed 2 birds with one stone. The off set is about 7-8 inches back from cab.
chevy2500 is offline   Reply With Quote
Old 04-21-2013, 10:04 PM   #16
Thanks for all the replies...I talked to the factory and since the Ford has a 6'9" box and the trailer has a TrailAire pin box, there shouldn't be a need for a slider 5th. Apparently the TrailAire pin sits forward around 5 - 6" as compared to "normal" pin boxes.
_______________
2011 Ford F350 Diesel Lariat with Firestone Airbags and Ford installed Reese Elite 18K 5th
2011 Cedar Creek 36RE Touring Edition - Loaded
Old 04-22-2013, 06:13 PM   #17
jevanb's Avatar
True, my superglide is wonderful and heavy
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
