Old 01-17-2019, 02:52 PM   #1
Do I need an electric brake controller for truck??
I just bought a R-Pod 180, that I will pull with my 2012 Chevy Silverado, and am wondering if I need to install an "electric brake" on my truck. The person that we bought the camper from had an electric brake installed on his tow vehicle. I have never pulled a camper before, and am hoping to get some good advice. Thanks in advance for any response.
Marcoman60 is offline   Reply With Quote
Old 01-17-2019, 02:54 PM   #2
Fulltime family RVer
I believe you do. The connector will be a 7-pin connection and your state will likely require it for something the size of the 180.
Old 01-17-2019, 02:58 PM   #3
To answer your "thanks" message - it wasn't a DIY job for me, but I'm not a "car-guy". I'm the guy who still has to think, "righty tighty, lefty loosey" when I pickup a screw driver. I think having one installed on my Durango was only about $300 and that included the Prodigy brake controller.
You might have a different level of proficiency.
Old 01-17-2019, 02:59 PM   #4
If camper has brakes than yes you need to install a brake controller on your truck
dodgemark is offline   Reply With Quote
Old 01-17-2019, 03:14 PM   #5
In PA, any trailer over 3000 # needs trailer brakes and a way to make them work.
Days Camped: '15=22 '16=46 '17=30 '18=51
Old 01-17-2019, 07:36 PM   #6
Depending on the model of your truck, you may be able to find a Plug in brake controller. When I had my trailblazer, I had to slice into the correct wires for the brake controller, for my 2014 Silverado there was a module I was able to plug into (had a Prodigy P3 controller on both). Both had a 7 pin adapter in back already.
ImTravis is offline   Reply With Quote
Old 01-17-2019, 08:01 PM   #7
I have a P3 brake controller with the plug in wiring harness for a GM truck I will sell. Drop me a PM if you wish.
USAF Retired
2019 Flagstaff 26RBWS
2018 GMC 3500 SLE
Msgtret is offline   Reply With Quote
Old 01-17-2019, 08:01 PM   #8
Flybob's Avatar
If the trailer has electric brakes, you need a controller. Don't skimp get a good one. Most of the good ones come with or have available a cable that will connect to the wiring in your TV without any cutting. Check your TV users manual it should identify the wiring color and location.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-18-2019, 01:51 PM   #9
rlh1957's Avatar
Anything over 2000lbs I would want brakes, and many have brakes because some states have laws requiring trailer have brakes and you have a way to make them work. If your trailer has brakes decent add on electric brake controllers can be had cheap and labor to install isn't that much but worth it to have a professional install them. Some vehicles have the pre-wiring to the trailer connecter already there, you just hook up the control unit, while some are prewired but you have to wire on a pigtail connector for your type of controller.
rlh1957 is offline   Reply With Quote
Old 01-18-2019, 03:42 PM   #10
Many years ago, when I was an ignorant newbie, I had a truck camper and a VW bug I was gonna tow with the rig. I had a tow bar made by a local welder and actually figured out how to connect the wires so the bug had lights. I didn't give a thought to brakes. Until we were driving down a straight mountain road in Wyoming, and I tried to slow down. I don't know what my VW weighed, but what ever it was it was enough to make the truck brakes useless. The was a cross road at the bottom of the mountain with a traffic light. All I could do was lay on the horn and flash my lights. Fortunately there was no cross traffic when I blew through the red light. I then looked for a rest room. I also never towed anything heavier than a log splitter without trailer brakes and of course, a controller.
DrLewie
Flemington, NJ
2007 Cardinal 30W LE
2008 Ford F-250 Long Bed Diesel
Total of 23 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
controller, brake control, electric, truck
