Old 05-01-2016, 05:51 AM   #51
shorthorn's Avatar
Nice rig... we just traded in our Cruise Light 281BHXL... It really was a great trailer. It was a 2012 and I had to replace all the tires on it in late 2013... all 4 tires were cracking badly around the sidewall... Not just normal cracks, these were deep and in a line around the rim. And they were never run below max inflation and had less than 1500 miles on them.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
shorthorn is offline   Reply With Quote
Old 05-01-2016, 07:54 AM   #52
Thanks. Yeah, I googled the tire brand on the trailer, Castle Rock ST's. Doesn't look good. Should probably replace those, as well.
Sent from my SM-T320 using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 05-01-2016, 09:12 PM   #53
Check load and speed rating
Trailer manufacturer's go with the least they can legally get away with, which usually barely covers the weight of the trailer, but not the weight we stack in them. Most trailer tires are rated for 65 mph (crazy), but if you look, you can probably find some that are 81 mph rated with higher load ratings. Worth the money.
I don't trust Michelin. I remember when the gov't. started requiring wear ratings on tires. Michelin's were some of the worst. I know their tires are better now, but I still don't trust them.
mnoland30 is offline   Reply With Quote
Old 05-02-2016, 08:28 PM   #54
jimmymjr's Avatar
I live in Florida and I've plugged tires for decades and pulled not only TT but gooseneck trailers loaded with farm equipment with no problems. If the plug is done right you should be fine but, new tires would be your best option.
[SIGPIC]Jimmy Miller
2016 27RKSS
jimmymjr is offline   Reply With Quote
Old 05-02-2016, 09:36 PM   #55
I'm so glad I let y'all talk me into some new rubber. These guys ride so much better than the old ones and have better traction. It's like the difference between that two-hour old piece of bubble gum that won't blow bubbles anymore and that brand-new piece of soft, pliable HubbaBubba. I didn't know it could be this good! They also threw in a "free" alignment and road hazard warranty. So I'm feeling pretty good right now (at least until the monthly payments start)
Sent from my SD4930UR using Tapatalk
Old 05-03-2016, 05:54 AM   #56
indybp57's Avatar
In the old days a plug was just a plug. Then at some point the dealers around here would not plug a tire - I was told they could no longer legally do it and they would unmount the tire and patch it from the inside. The plugs they use now have a patch on the end - they shove the whole thing into the tire and the patch expands on the inside and so they are able to patch a tire while its still on the rim. Looking at it you think "the bast ____s plugged my tire!" When in reality its a patch.
2013 Roo 183
Miles Driven/Nights Camped:
2012:1042/13 2013:2772/27
2014:2259/30 2015:1644/20
2016:1278/23 2017:2183/22
indybp57 is offline   Reply With Quote
Old 05-03-2016, 07:55 PM   #57
wmtire's Avatar
I can't say that I have ever personally seen that. A patch/plug insert is inserted from the inside of the tire. You still have to buff/clean the tire's innerliner for a patch to properly adhere to the tire and make an airtight seal. You also have to use a cutter to prepare the injury hole for the insert. Those carbide cutters aren't cheap either as I just had to buy two replacements last week for around $65 per.
To meet RMA standards, which most all tire manufacturers are members of, here is the proper repair techniques for small tires.
https://www.rma.org/wp-content/uploa...lchart1111.pdf
and here is the repair procedures from Tech Int., which is the brand of repair materials we use in my business.
http://www.techtirerepairs.com/conte...ra-Repairs.pdf
As noted, ALL repairs are done from the inside of the tire.
If someone in the same tire business as me told you otherwise, you may still have reason to call them a bad name.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-03-2016, 08:16 PM   #58
Now that I've got new tires on the TV, do you think the trailer tires will make it 4000 miles? I know they are China bombs, but they are brand new and I bought a TPMS.
tire, tires
