Old 04-11-2016, 10:58 AM   #1
Do the dry weight sticker include the hitch?
Dry weight does that include the weight of the attached hitch, minus battery and propane tanks? They yellow sticker shows dry weight... I'm thinking the whole unit with hitch was weighed by manufacturer. As it was bulit when it left the manufacturer, includes hitch where the propane and battery sit on?
DebMar is offline   Reply With Quote
Old 04-11-2016, 11:00 AM   #2
Dry weight does not include hitch since different brands weigh different amounts. You should look for a yellow label (usually found in the door jamb of the camper) to see what the camper weighed when it left the factory.
It should include propane weight per the regs issued in 2007:
The FMVSS 571 says;
S9.3.2 The weight value for load carrying capacity on the RV load carrying capacity labels (Figures 3 and 4) must be displayed to the nearest kilogram with conversion to the nearest pound and must be such that the vehicle does not exceed its GVWR when loaded with the stated load carrying capacity. The UVW and the GVWR used to determine the RV's load carrying capacity must reflect the weights and design of the motor home or RV trailer as configured for delivery to the dealer/service facility. If applicable, the weight of full propane tanks must be included in the RV's UVW and the weight of on-board potable water must be treated as cargo.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2018: 24 nights camped
Teamfour is offline   Reply With Quote
Old 04-11-2016, 11:02 AM   #3
PhoneDude 8289's Avatar
Dry weight or UVWR "unloaded vehicle weight" is as it left the factory. Anything added after it left the factory is added weight.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 04-11-2016, 11:17 AM   #4
Okay yellow stick shows 4857. When left factory doesn't the hitch (where the tanks and battery rest on) come with the camper when shipped? Is it called hitch?? Sorry, new and confused.
Old 04-11-2016, 11:19 AM   #5
Sorry, I thought you were referring to the WDH hitch. Yes the frame where the battery and tanks rest is included since it is an integral part of the frame.
Lee and Anne
Old 04-11-2016, 11:25 AM   #6
PSUFan1's Avatar
I believe Debmar is referring to the "tongue". As mentioned this is part of the trailer and would be included in the yellow sticker weight.
2012 Ford F-150 EB Crew FX4 3.73 gears
2012 Micro Lite 23lb
Tim & Tracy, Jennifer (16), Alyssa (11), our dog Jazy
2012 Ford F150 EB Crew FX4 3.73 gears
2017 Grand Design Imagine 2800BH
Previous: 2012 Flagstaff MicroLite 23LB
2006 GMC Envoy Denali V8 & 2005 GMC Envoy I6
PSUFan1 is offline   Reply With Quote
Old 04-11-2016, 11:30 AM   #7
The weight of the empty propane tanks are also included.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 04-11-2016, 11:56 AM   #8
CWSWine's Avatar
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Read the post from Teamfour above or go to FR site and read what is included in the UVW weights. They do include propane not just the empty tanks anymore.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 04-11-2016, 12:26 PM   #9
RetiredRVer
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
The weight includes "full" propane tanks. See Teamfour's post above.^
checkmate99 is offline   Reply With Quote
Old 04-11-2016, 12:40 PM   #10
Quote: "If applicable, the weight of full propane tanks must be included in the RV's UVW and the weight of on-board potable water must be treated as cargo. ".....................
Notice the term "if applicable". That opens the door to interpretation. And lawyers love words like those in laws. But then one must remember most politicians were lawyers.......
Happy trails,
billb800si is offline   Reply With Quote
hitch, weight
