Old 06-10-2014, 06:12 PM   #31
dcheatwood's Avatar
Originally Posted by Jammer3025 View Post
When the TT is attached to my truck the T/H mode is on.
X2
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 06-10-2014, 06:50 PM   #32
dsrace's Avatar
Originally Posted by Brother Les View Post
For a F-250 7.3 2400rpm @ 60mph ,rpms is way to high and asking for trouble. You should go to a Ford Truck Forum and get into the thread are of your truck year and talk to them about what you have. It may be fine for you, (I don't know), but for me it would not be good.
Ford Truck Enthusiasts Forums - Ford truck and SUV owners and enthusiasts Community And Information Source.
a dp tuner adds trans shift points for pulling which is a huge plus and out of od in 3rd gear in that trans which is most likely a 4r100 or e4od trans at that rpm you must have 3.55 gears cause with 4.10's you'd be at 2800 rpm ish at that speed. i have had 3 ford 7.3's and 1 was an auto with 4.10's. if you read the owners manual in your f250 psd you'll see that it states to pull in od, i added a bigger and better trans cooler and gauge just so i knew. and the bigger cooler was real easy to install and dropped the trans temps down 25* on the interstate at 75 mph towing my toyhauler loaded at almost 11k lbs.
'99 f350, quad cab long box, dually, 6 speed manual, gently mod'd.
2011 wolf pack 295 with full susp now!
dsrace is offline   Reply With Quote
Old 06-10-2014, 06:59 PM   #33
Terier's Avatar
I push my tow/haul button but honestly have no idea what it does/doesn't do.
Me too. I only use the tow/haul.
Once I used the cruise control while towing and the ride was fine. On the return trip there was too much traffic so I didn't use it.
As to why I haven't tried it again is that I can't remember how to turn on the cruise control and I haven't care to look it up in the owner manual. Even worse I didn't know how to use the cruise control in my previous two cars either. (OK, I'm odd )
Old 06-10-2014, 07:30 PM   #34
boatman
boatman's Avatar
I just push the Tow/Haul button once on the Allison trans which modifies shift points and allows for trans braking on hills if you push button twice it
Locks out OD never needed to do that I set Cruise control as soon as I can at 67 mph
boatman is offline   Reply With Quote
Old 06-10-2014, 07:43 PM   #35
Crusadernoob's Avatar
We always use tow/haul when hooked up, we also use cruise control when on relatively flat ground, I've tried it in 6th gear and 5th gear, it makes no difference on mpg for us.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 14
Crusadernoob is offline   Reply With Quote
Old 06-10-2014, 07:51 PM   #36
BamaBob's Avatar
Tow/Haul always on, flatline interstates Cruise always on. Hilly areas usually go to manual because I am more interested in gas milage than speed
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 06-11-2014, 02:38 PM   #37
I don't have a tow/haul mode, but I do turn OD off. From reading about it for Fords, it seems you can leave it on if you don't have excessive shifting. But I turn it off anytime I tow.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 06-11-2014, 02:50 PM   #38
Sturgie's Avatar
My tundra 5.7 won't pull 6th, and I don't want it shifting to 6th even on descents, so that's why I use manual mode and keep it in 5th. The 5.7 will struggle in 5th if there is a bad headwind. A diesel is pretty carefree about hills, wind, cruise control..... wish I had one : )
Sturgie is online now   Reply With Quote
Old 06-11-2014, 02:58 PM   #39
Brother Les's Avatar
Originally Posted by Sturgie View Post
DDC,
I'm tired of hearing all buddies at work brag about their diesel towing massive weight with the cruise control..... lol! If I would've know, i probably would have went that route. Someday I'm sure.
Someday is today, for tomorrow will never come.
Brother Les
Old 06-11-2014, 05:34 PM   #40
When it's time to replace the Explorer and my B3000 I have thought about going to a diesel pickup for my tow vehicle. It won't be anytime soon as we just got a new car for the DW and the Explorer is still running great. My guess is sometime after that we will start looking at 5th wheels to take advantage of the higher towing capacity.
keith_h is offline   Reply With Quote
towing
