Old 06-10-2014, 12:20 PM   #1
48fan's Avatar
do you turn your cruise control off when towing tt
do you turn overdrive off when towing tt . what is the difference in rpms
2014 coachmen clipper 15RB
2000 ford f-150 super cab 4.2 6 cyl
48fan is offline   Reply With Quote
Old 06-10-2014, 12:28 PM   #2
On highways at 100 km/h I usually put it ON
But on secondary roads at 80 or 90 km/h, I turn it OFF
The transmission downshift more often and the rpm's go up a lot when using the cruise.
Black is offline   Reply With Quote
Old 06-10-2014, 12:35 PM   #3
Ford Idaho's Avatar
I run with mine on as well as use the tow/haul unless I am in town or traffic.
Ford Idaho is online now   Reply With Quote
Old 06-10-2014, 12:40 PM   #4
Ret E-9 Anchor-clanker
donanddona's Avatar
I put (Tundra) tow haul mode on, selector lever in drive 5, cruise control set at 53mph. 9mpg!!!
donanddona is offline   Reply With Quote
Old 06-10-2014, 01:00 PM   #5
Steelframer's Avatar
If you turn your OD off while towing, your trans will work harder and your trans oil pressure will drop, which in turn will not lubricate and cool your transmission as much as if you had it in drive/towing gear.
You will be running the risk of very costly repairs just for a few $$ of savings in fuel. Not worth it IMHO.
Steelframer is offline   Reply With Quote
Old 06-10-2014, 01:02 PM   #6
I push my tow/haul button but honestly have no idea what it does/doesn't do.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 06-10-2014, 01:09 PM   #7
parpar1's Avatar
Hey leave it in overdrive but if you are towing push the tow/haul button. It simply knocks it down a gear for lack of a better explanation. Otherwise you are putting a heavy load on the tranny. That button is almost like another gear.
parpar1 is offline   Reply With Quote
Old 06-10-2014, 01:11 PM   #8
Devilscreekw's Avatar
Always run with my tow haul button on. Raises shift points and locks out overdrive. I can achieve full lockup in fifth gear unless I have a headwind. 2010 Ram Hemi (393 hp, 408 ft/lbs). 60 mph at about 1800 RPM.
Harv & Deb
2015 Flagstaff 27RLWS
2010 Ram 2500 4x4 crew 5.7 Hemi, 3.73
Equalizer 1200 4 pt. Tekonsha controller
Devilscreekw is offline   Reply With Quote
Old 06-10-2014, 01:13 PM   #9
Brother Les's Avatar
I leave my Overdrive On. RPMs, 1700 at 65mph. I do use my cruise control out on the open road where there is no traffic that is in my way or I am in their way. I have a beefed up transmission and run a Chip that has a tow setting.
Brother Les
Old 06-10-2014, 01:14 PM   #10
BeedoGoesCamping's Avatar
Ford F-150 EcoBoost; Tow/haul on and cruise on if on interstate, off if in town/back roads. 12 mpg.
The Covingtons
"Freshman campers!"
2014 Avenger 32BHS
2013 Ford F-150 Eco-Boost Super-crew cab
Number of days camped in 2014: 10
BeedoGoesCamping is offline   Reply With Quote
