Originally Posted by sideout1961
Anybody out there have the 2500 with the Reese Duel Cam setup? Had it for my Tundra and was wondering if I need to adjust the drop on the hitch. It's a 12 drop and I have almost 2 holes showing. Also had 3 links hanging will this also need to be changed. My dealer wants to charge me 100 dollars to make any adjustments needed so wanted to check with the group for any advice.
Start from scratch - break out your measuring tape. You don't specify but I'll assume that you're running with the trunnion style system - the trunnion bar system is more widespread than the round bar Strait Line systems. Setup instructions for the trunnion bar systems relative to the size of your bars, can be found here:
Weight Distribution - Reese
The dual cam setup details are here:
The setup for the round bar system is the same as the trunnion bar. The difference is in the ball mount and the way in which the ball tilt is adjusted.
Yep, pain in the kazoo to be sure but I'd be wanting to verify that the system is perfectly tuned to current TV.
