Old 12-14-2013, 09:36 AM   #31
I wouldn't get too worried about the 3.73 gears. That truck still has the same suspension and brakes as the truck with the 4.10's so only the transmission and engine will feel the difference in gears. When the 4.10 equipped truck is in 3rd gear yours might be in 2nd. It's still going to get the unit rolling fine, my old Cummins Dodge had 3.55's in it. Yeah it has a Cummins but that doesn't change the amount of force on the transmission that it took to take the truck to get rolling. My dad had the same equipped Dodge and he was towing a 12,000 lbs Aplinelite 5th wheel. Get what trailer you want within reason and monitor your transmission temp which you should be doing with any tow vehicle.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 12-14-2013, 01:11 PM   #32
Steve Jackson
sideout1961's Avatar
Thanks for the advise makes me feel a lit better about my purchase
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 12-15-2013, 06:16 AM   #33
Incheon, S. Korea
BigBaron's Avatar
Just shift manually on hills. Enjoy your new toy, er, truck!
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 12-15-2013, 11:07 AM   #34
rracer5's Avatar
Originally Posted by sideout1961 View Post
Is it an expensive job to switch to 4.10 ratio? Or is there more involved? Right now the only thing I gained going from the tundra to the 2500 was 400 lbs more towing and more bed payload which is not a big deal cause I don't carry a lot of cargo in my bed.when we go camping.
Sorry, didn't mean to scare you by suggesting you would have to make a bunch of mods to your new truck. I agree with GearHd6. Just choose what you're comfortable with and have lots of family fun.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is online now   Reply With Quote
Old 12-18-2013, 10:20 AM   #35
My advice is to go to your dodge dealer. A 2500 is the same as a 3500 minus a set of rear leaf springs. Talk to them and get them to do the 2500-3500 mods whatever they are. I don't think it will cost much. Then you can see what the ratings are for a 3500 configured like your truck with 3.73 rear end. If that's not enough then you may have to go to 4.11's but that would be an expensive last resort. A good dodge dealer that moves a lot a heavy trucks will understand this. You can get the truck rated to a 3500 pretty easily.
Now everyone knows the legendary power of he cummins power plant. The truck won't have the raw towing power of a diesel 3500. If your towing heavy though you will actually have more payload capability than a cummins equipped similar vehicle. That doesn't mean it will tow as powerfully the same load but you will get there just slower.
The hemi is a great engine.
MikeRP is offline   Reply With Quote
Old 12-18-2013, 10:46 AM   #36
I believe you'll find that the 2500 and 3500 are equipped the same when it comes to engine, transmission and all cooling items. You'll find the difference is only in the axles, springs and brake size. I still don't think 4:10's are necessary.
2013 Rockwood 2109S
Old 12-18-2013, 01:00 PM   #37
transamz9's Avatar
The axles and brakes are the same.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 12-18-2013, 04:43 PM   #38
Agreed there is no difference between the 2500 and 3500 trucks except and extra set of leaf springs in the rear. No difference in brakes, axles, shocks. Nothing expect that little sticker on the door. That's why you go to the dealer have him put on the rear springs and verify the new payload capacity, gcvwr, gvwr etc so that you have the record.
Major difference for a set of leaf springs.
Old 12-18-2013, 06:39 PM   #39
Huh, back in the day the 3500 got you bigger Dana axles than the 2500. Times have changed I guess.
2013 Rockwood 2109S
Old 12-18-2013, 07:40 PM   #40
RKR
RKR's Avatar
I believe you are correct. I think the 3/4 tons had Dana 44's and the 1 ton had 60's if I'm not mistaken.
RKR is offline   Reply With Quote
