Old 02-17-2011, 06:08 PM   #1
Redheaded blue tick's Avatar
Question Dodge-- gas vs diesel??
We have ordered a 2011 Rockwood 3008W and are looking to upgrade the truck also. Does anyone have personal experience or info regarding pulling the V-nose trailer with either a Dodge Hemi or Cummins diesel truck? What kind of mileage are you getting with either engine and have you come across any real problems with either type. Thanks for your input.
Redheaded blue tick is offline   Reply With Quote
Old 02-17-2011, 06:32 PM   #2
M109Rrider's Avatar
Not pulling a trailer identical to yours but pulling our old 7k TT. Pulled it with an 04 Ram w/HEMI and a 05 W/Cummins. Day and night difference. Averaged 8 with the gasser and never lower than 13 with the diesel. More importantly the Cummins pulled effortlessly, set the cruise and forget it. The HEMI constantly was hunting for gears, the diesel shifted to high gear and stayed there until you started pulling a grade. I personally will never own another gas truck.
Jason and Billie
2005 Dodge Ram 2500, 4X4, QC/SB 5.9L Cummins
15k non-sliding Hidden Hitch (they lied, it's not hidden at all)
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 02-17-2011, 06:35 PM   #3
Head Rambler
I've owned both the 1500 with a Hemi and currently own a 2500 Mega with the Cummins. Our RV weighs just shy of 7,000 lbs and I can tell you that the Cummins wins the pulling contest hands down. It also wins the fuel mileage war when towing. I get about 14 mpg with the Cummins towing and got about 9 to 10 mpg towing with the Hemi. They're about even when running empty, but with Diesel running a bit higher it's not the most economical of the two.
Gotta go campin!
Old 02-17-2011, 06:40 PM   #4
First question I have to ask is what is the trailers GVWR????
That will determine which engine will be the best choice.
Old 02-17-2011, 08:16 PM   #5
Glenn5995's Avatar
The 3008W has an empty weight of 6544 and a GVWR of 8742. It would be within the capabilities of a properly equipped Hemi Ram, but will be close to its limits unless you travel very light. Many don't like the way the Hemi makes its power at higher RPMs, but that is a matter of personal preference. The Cummins would of course have no problem with it and allow you to move up into a larger trailer at a later date if you so desired.
My Power Wagon with 4.56 gears averages 8.5 MPG towing our fifth wheel with a similar weight. I would get the diesel if it were available in a Power Wagon, but it isn't. For me I prefer the Power Wagon over a Cummins non-Power Wagon Ram and so far it has hauled our fifth wheel all over the West (13 states so far) for the last 5 years without fail. That include 3 trips on I-70 to the Eisenhower Tunnel. A 7% grade to over 11,000 feet.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 02-17-2011, 08:43 PM   #6
CampeRooo
rthrbelsewhere's Avatar
Originally Posted by M109Rrider View Post
.... I personally will never own another gas truck.
I second that statement. I owned an 04.5 6-speed version and then traded it in for the 06 automatic version because my wife said that she wanted to drive it too. She's driven it twice so far, so yea...that was a good payoff...NOOOT! (Truth be told, I miss my 04.5).
Joe
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 02-18-2011, 12:16 AM   #7
Had both, Cummins like most have post here it wins hands down. Had a 06' 1500 Hemi and a 21' TT, maybe I didn't have the right rear end...but it was always hunting gears and seemed to be always pushing the envelope...especially into a good wind.
Fuel mileage was anywhere between 8 and 11 on a good day. The 09 2500 with the Cummins is less stressful driving even though its bigger trailer...and the engine brake is fantastic. Fuel mileage is 12 on a bad day and I have had as high as 15 mpg.
If you go the Cummins route, get the biggest fuel tank they offer, a pain in the wallet to fill, but way less stops which is great, I hate manevering around gas stations that weren't designed for RV's.
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 04-26-2011, 11:36 AM   #8
I just got a F250 and the diesel, at just under $8,000 more, is the only way to go! Pull more, better MPG and last a lot longer. I have heard that some have problems with a Dodge standard? I got the auto, but would like to know if the standard does ok?
whj77372 is offline   Reply With Quote
Old 04-26-2011, 12:05 PM   #9
Wanna Be Camper
SaskCampers's Avatar
Averaged 11.2 mpg over 6000km. Hemi Megacab 4x4, and it needs to make no excuses for power although a diesel will run away from it on long hills it still has power to pass semis on hills. Would I ever own another Dodge diesel or gas? Not in this life or any other after 42 trips for warranty in 25 months and it still wanders around like a drunk sailor, but the heater at least worked this winter.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
Old 04-26-2011, 12:32 PM   #10
M109Rrider's Avatar
Drunk sailor......I'm offended........and resemble that remark
Jason and Billie
