Old 08-24-2016, 09:44 AM   #21
rracer5's Avatar
Originally Posted by emm-dee View Post
Do you have the uConnect system?
There is a uConnect button on my radio but it's not active.
Am I correct that uConnect is a "pay" subscription service like my satellite radio?
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 08-24-2016, 12:45 PM   #22
Usually Confused Member
emm-dee's Avatar
UConnect is the name for the system. There is a uConnect 5 and a uConnect 8.4. Basically the number is the size of the screen. The 8.4 has all the pay stuff.
The -5 has a settings button:
That takes you here:
The up down arrows show different settings options. Press "Trailer Brake" and you get this screen
Select trailer one and
When you press trailer type you'll see
Select what you want and you're done.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 08-24-2016, 09:19 PM   #23
rracer5's Avatar
I guess I don't have that option. This is the system I have.
My setup in the information center doesn't have any trailer brake settings when i scroll down. The radio setup, only has Sirius ID and Clock.
ID:	118394   Click image for larger version
2014 Sanibel 3250
Old 08-24-2016, 10:28 PM   #24
emm-dee's Avatar
I haven't seen that setup. But, if you have the integrated brake controller I would think there's a way, somewhere somehow, to set it up. I only know about the ones controlled via the uConnect.
Have you tried getting help from the dealer? Or, check out ramforumz or ramforums boards. Some really smart folks hanging out there.
Old 08-24-2016, 10:44 PM   #25
rracer5's Avatar
I put the question out on dodgeforums.com but no responses yet. Thanks for your efforts emm-dee.
2014 Sanibel 3250
Old 01-22-2017, 02:08 AM   #26
n1joh's Avatar
You do it off the steering wheel I have a 2016 ram 3500. You go to towing and set it.
Sent from my VS985 4G using Forest River Forums mobile app
n1joh is offline   Reply With Quote
Old 01-22-2017, 07:27 AM   #27
The settings in the display of the radio are only at 5.0 and higher.
In lower trim levels with 3.0 the access is, like said, in the center display. The difference between ld and HD is the max power and the electronic gain curve, which is progressive. If you change the settings, you just limit the max power to the brakes. HD has a more linear output with higher power applied.
The trailer settings are accessible, when the trailer is hooked up.
Using HD on a ld trailer can result in brake rubbing, because of the more linear power application. The setting depends also on the individual trailer brakes which makes it impossible to suguest a specific setup. Once the program is chosen, change the gain while driving and find the best setup for your own trailer.
Hope that helps a bit.
chrisf65 is offline   Reply With Quote
Old 01-22-2017, 08:28 AM   #28
I had that setup in my 11 Ram 1500 hemi 4x4 big horn. I could change my brake controller through the in dash set up menu between the speedo and rpm gauges.
If I still had the truck I would take picks for you but traded it last month for a
2014 Ram 1500 Crew Cab Ecodiesel Laramie.
We tow a 2016 Wildwood 30kqbss which is 6800# dry. I use light electric and set gain to 7.5 and works pretty well
Marty, Carla, Gabby and our ankle biters Rocky and Addy
2014 Ram 1500 Crew Cab Laramie Eco Diesel
Forest River Wildwood 30KQBSS
eyeguy1 is offline   Reply With Quote
Old 01-22-2017, 10:21 AM   #29
Homebrew's Avatar
We tow a XLR Thunderbolt 300x12 around 16K #, heavy trailer setting @ 4.5
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-22-2017, 04:29 PM   #30
rracer5's Avatar
I've tried but, could find no way to make any changes. If you could remember any of it, please let me know. Unless like others have said, I need to be hooked to the trailer.
Sounds like they made it so much easier on the 2012 & up models.
2014 Sanibel 3250
brake control, controller, dodge
