Old 10-09-2012, 08:20 AM   #1
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
Does anyone recognize these brackets ?
Just looking for some help identifying these brackets. I am hoping they are for a weight distribution hitch on the 6500 series VCROSS units.
I had a closer look under my trailer and noticed that there are "factory" installed brackets about 27 inches back from the ball hitch. Does anyone on the forum recognize this as a possible standard bracket mount for an "equal-i-zer" weight distribution hitch. See attached photos I took of my VIBE 6504. Brackets are just under trailer floor.
ID:	20404   Click image for larger version
2015 Rockwood 2306 MiniLite
2012 Chevy Traverse
2011-2014 - 50 nights
Paul, Darcie, Li & Yan
pdchristensen is offline   Reply With Quote
Old 10-09-2012, 01:15 PM   #2
Fire Instructor's Avatar
If they are only on one side of the "A-frame", then they may be a bracket left from some kind of friction-type anti-sway. The newer ones bolt directly on, but some of the older one's varried in how they mounted.
Fire Instructor
2014 RAM 2500 Laramie 4x4 Quad Cab w/Cummins Turbo Diesel, 2009 Rockwood 2607, and 3 'yaks!
300W of Suntech Solar, a Rogue MPT-3024 Controller, and a Xantrex PW2000 Inverter
Fire Instructor is offline   Reply With Quote
Old 10-09-2012, 01:20 PM   #3
They are on both sides of "A" frame as per the 2 photo's (one for each side). They are likely not "left over from previous anti-sway" as the trailer is a brand new 2013. One of the other VCROSS owners suggested it was likely a "factory install" bracket for an equalizer hitch. I am trying to determine what make & model might fit this custom bracket.
2012 Chevy Traverse
Old 10-09-2012, 01:21 PM   #4
Sorry. Didn't realize the photos were from two different sides. That's what I get for looking at them on the handheld....
Fire Instructor
Old 10-09-2012, 01:50 PM   #5
Willybgh's Avatar
Quite possible for equalizer as the distance from the ball seems to be right. I have the equalizer and the only difference I see is that there is a weld instead of bolt at top and it is missing the L bracket.
Chris
TV: 2007 GMC 1500 Crew Cab 5.3L
Brake Controller: Tekonsha P3
Hitch: Equal-i-zer 4 point wd/sway control
Trailer: 2015 Cherokee 274RK
In Past:
2011 Grey Wolf 26RL, 2009 Cikira 19 EXP hybrid, 2008 Clipper 108st (pop-up)
Willybgh is offline   Reply With Quote
Old 10-09-2012, 03:45 PM   #6
wmtire's Avatar
You can hear what the salesman at the 1:40 mark of this video says about them.
It looks like to me that the bolts would line up for the Equalizer WDH.
http://www.equalizerhitch.com/pdf/eq...anual_0111.pdf
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-09-2012, 05:02 PM   #7
troyt's Avatar
Fairly confident that they are brackets for the Equal-i-zer hitch.
2006 Dodge 2500 Crew Cab 5.9L Cummins 4X4 200k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (?)
troyt is offline   Reply With Quote
Old 10-10-2012, 07:22 AM   #8
thanks...Troyt & Wmtire. You have helped me solve the mystery. It is good to know it will be easy to equip my unit with a weight distribution hitch. First thing on my agenda for the spring trailer prep next year.
2012 Chevy Traverse
Old 10-17-2012, 03:59 PM   #9
thebrakeman's Avatar
Yes, that is part of the Equal-i-zer brand WDH kit. Getting the L-brackets and attachment bolts is easy. But by the time you buy the head unit and spring bars (separately), it would be much cheaper to just buy an entire kit.
I recommend RVWholesalers.com. Around springtime, they usually have a great sale on these.
thebrakeman is offline   Reply With Quote
