Originally Posted by boatnut
I have a 28' Class C motorhome. I think if I do any extensive traveling, it would be nice to have a small vehicle for side trips etc. What are the pros and con's to using a dolly vs. hooking direct (or whatever you call it) ?
You will likely get lots of opinions on this topic.
I would say the pro is mainly the cost and you can tow just about any front wheel drive vehicle (within weight limits of course) so if you have multiple vehicles, you don't need to set up each one to be towed 4 down.
The main con is getting the car on the dolly and then hooking up the safety chains as the typically requires one to get on the ground and reach under that car.
You also need to be able to store the dolly somewhere when not in use.
The pro for towing 4 down would be the ease of hooking it up. The con would be the cost (I'd say typically in the $2k to $4k range) for each vehicle you want to tow. You also need some kind of auxillary braking system on the vehicle - with a dolly, the dolly will typically have its own braking system.
Hope that helps a little.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
