Old 11-15-2013, 12:38 PM   #1
jevanb's Avatar
Don`t dyno a echoboost
buddy at work bought a 2014 echo boost top of the line fx4 or something. took it to our buddy at diablo sport (the owner) and he wanted to see the HP/TQ #`s no tuning all factory. the only thing that was remove is the speed limiter (cant get enough speed to work the dyno with the factory limiter) not sure what #`s he saw but the crank snapped. he is hoping the dealer will take care of this. sucks to be him...
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 11-15-2013, 01:04 PM   #2
Now a "Top Member"
EdJunior's Avatar
Hoping indeed. Sounds like he is outta luck. Some people just can't seem to be happy with things as they are.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
Old 11-15-2013, 01:05 PM   #3
TURBS's Avatar
how many miles were on it ?
Old 11-15-2013, 01:40 PM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
JevanB stated the truck was stock...just running it on the dyno for real world HP/Torque ratings to compare to Ford's advertised #'s...it's ashame ANY stock truck should break under this simple test
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 11-15-2013, 01:45 PM   #5
Oakman's Avatar
I hope things work out OK for your friend. I think if the dealer checks the Event Data Recorder your friend will be SOL.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 11-15-2013, 01:57 PM   #6
TURBS's Avatar
Originally Posted by cajun po-boy View Post
jevanb stated the truck was stock...just running it on the dyno for real world hp/torque ratings to compare to ford's advertised #'s...it's ashame any stock truck should break under this simple test
i agree
Old 11-15-2013, 02:04 PM   #7
fonzie's Avatar
"the only thing that was remove is the speed limiter (cant get enough speed to work the dyno with the factory limiter)"
There must be a reason for speed limiter...........
Fonzie
Old 11-15-2013, 02:21 PM   #8
DDC
DDC's Avatar
Why would he need to remove the limiter, the dyno should be able to give readings though the whole range at least the one I use to operate for GM did each gear and at all recordable RPM's.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 11-15-2013, 02:36 PM   #9
TURBS's Avatar
The reason its in place is so you don't go over 100mph at any whim/ drunken state you want.
As long as the "rev" limiter wasnt raised/ removed the speed limiter shouldn't affect anything but a higher speed.
Correct?
So the speed is limited to 100mph removing it to go 120 should have no Ill affect as long as the engine isn't above max rpm .
Right?
Old 11-15-2013, 02:42 PM   #10
jevanb's Avatar
the engine needs RPM to spool turbos and with rpm comes MPH , kind of hard to get them to light without it. I see over 100 trying to get mine to light the top charger. it would be worse without the VGT on the bottom.
Correct?
Right?
true, I guess they needed the MPH, funny thing he let them have the truck while he was on travel, but I bet daddy will pay for it if the factory will not. his last project is a Z06 with 675hp
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
