Old 03-01-2017, 02:21 PM   #21
dannyabear's Avatar
Never mind being over weight, that poor little 4.7 will stay 'wound up' trying to pull it.
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 03-01-2017, 02:50 PM   #22
Dry weight is what determined my license plate fee.
aeblank is offline   Reply With Quote
Old 03-01-2017, 02:51 PM   #23
I have a 2017 5.7L
You will be disappointed I think if you go to hill country. I have the newest of the new 5.7L and will be adding back end reinforcement for lift. Mine is a $50K truck meant for this and It needs some enhancements. It pulls fine and I can pass folks uphill etc. But I would like more power. The truck is 7 weeks old and I am pulling a 2017 FR 117KL Ice house . I have power but it could tow better. So going to do some upgrades. Just my $00.02
TonyShope is offline   Reply With Quote
Old 03-01-2017, 02:52 PM   #24
Who Dares, Wins
doc73's Avatar
Your lucky ours is determined by GVWR. But it is $25 for a trailer.. Gets pricey for the TV.
2015 Chevy HD D-Max
2022 Impression 315MB
doc73 is offline   Reply With Quote
Old 03-01-2017, 03:33 PM   #25
keeprr's Avatar
After pulling with a 1/2 ton and now having a 2500 I can't imagine towing with anything less. Bigger brakes, bigger rear end, stronger frame and suspension it's the only way to go. I personally chose the diesel but either gas or diesel, do yourself a favor and step up to a 3/4 ton.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 03-01-2017, 03:35 PM   #26
drittal's Avatar
I wouldn't. The 4.7 isn't a powerhouse. You won't be happy.
drittal is offline   Reply With Quote
Old 03-01-2017, 03:56 PM   #27
That might be the intent. I was more than 1200# and less than 10,000#, so it was $200. Dry or GVWR falls in the same range.
Don't get me started on the TV registration. $232 is a pretty big pile of.........something smelly.
No doubt! Do note the above added cost(s).
Old 03-01-2017, 04:00 PM   #28
Who Dares, Wins
doc73's Avatar
Yeah I am in the $200 range for a class 4a registered weight.
2015 Chevy HD D-Max
Old 03-01-2017, 04:07 PM   #29
That $200 was permanent, at least.
Old 03-01-2017, 04:10 PM   #30
Who Dares, Wins
doc73's Avatar
Yearly here for truck and trailer.
2015 Chevy HD D-Max
Old 03-01-2017, 04:18 PM   #31
I usually chime in against the weight police crowd and think a 1/2 ton truck can pull a 7-8k camper no problem if it has a 10k plus rating. Dont think your older truck with the smaller engine is going to cut it. Get yourself a new 1/2 ton with a 10k plus rating and have at.
Kimber45 is offline   Reply With Quote
Old 03-01-2017, 05:09 PM   #32
Tom48's Avatar
Originally Posted by jvahicks View Post
Thanks for all the input and opinions. I couldn't get the payload info off the truck as it is still at the dealership. Unless they come in with a great price I will probably pass. It would probably do the job here in the flatlands we live in and none of our trips are over 150 miles usually a lot less. So again thanks for the information.
There we are at the root of the problem. THE DAMN SALESMAN WILL SWEAR IT IS ALK THE TRUCK YOU NEED.. HE IS PROBABLY WRONG OR OUT AND OUT LYING TO YOU.
ALSO, I note our 04 does not have load capacity clearly stated in the door panel sticker. And 05 might not either. Take the truck for a test drive straight to the cat scale. Wiegh it. Allow an add on for your full fuel, about 7lbs a gallon, your people and junk, then subtract that total from the trucks GVW. What's left is your load capacity.
Don't cheat or lie to yourself. Your safety and that of your family and maybe one of our families is at stake.
Tom48 is offline   Reply With Quote
Old 03-01-2017, 05:49 PM   #33
Maybe
Originally Posted by OldCoot View Post
You forget the trailer is supposed to stop itself with its own brakes.
I would never bet my life on the trailer brakes being able to stop it. After 22 years of fulltiming I want good truck brakes first.
VMI'62
Edmund is offline   Reply With Quote
Old 03-01-2017, 05:56 PM   #34
Then nobody should tow.
rat4spd is offline   Reply With Quote
Old 03-01-2017, 06:36 PM   #35
Pulled this off airforum.com today:
"We hit the "perfect storm" and rolled our beloved 2003 Airstream Classic (thankfully we were not injured). A cold front coming in with wind gusts, down steep hill and tractor trailer going to fast by us caused the trailer to sway and tip both trailer and TV (Ford Excursion V10). We pulled our '75 Airstream Excella for 10 years without sway problems."
Unfortunately, I don't know the length of the trailer or its weight, nor the capacity of the Ford Excursion V10, though it could easily be researched. Obviously, the owner successfully "pulled" that trailer for many (10) years.
My first response would be that the minimum tow vehicle should be a 3/4 ton diesel truck. At least that is what I would pull a 30 foot Airstream Classic 10,000 pound trailer with. And yes a 2017 F150 is rated to pull it, but that truck is around 2,000 pounds lighter than a 3/4 ton truck.
As previously discussed..."pulling" is not the only issue.
Fortunately the owners are still alive, but in that forum seem to be focused on a better anti-sway hitch. Maybe they are right, that is all that they needed??? Don't think they want a do-over.
I think it is fair to say the trailer controlled the tv...which is back to should you pull a heavy trailer with a light truck even if within the legal rating??? Myself, I want lots of extra tv capability. I bet that a 3/4 truck would have held onto that trailer and not rolled with it...but can't prove it.
As to trailer brakes, my understanding is that it is not tow savy to rely on them, particularly going down a steep mountain. Can't imagine anyone believing that.
Philos3 is offline   Reply With Quote
Old 03-01-2017, 07:04 PM   #36
Insert witty title here
Trailer brakes should be viewed as something nice to have but not required. In the absence of a trailer braking system, the TV should be capable of stopping the trailer on its own.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 03-01-2017, 07:09 PM   #37
I guess OTR semi's need to be able to stop the their 40-50,000# trailers also without trailer brakes. Never happen. Your reasoning is a little off. IMHO
Old 03-01-2017, 07:16 PM   #38
If I had to think of betting my life on every variable out of my control, I could never leave the house. A dually should be able to stop upto 30,000#? It's okay that a 3/4 ton must be able to stop up to 18,000# give or take, but a 1/2 ton isn't capable of stopping 9000#? Or the millions of OTR truck maxed out at 80,000# with a 65,000# trailer. Those tractors are stopping that?
If you think your trailer is incapable of stopping itself, maybe you should be concerned about your trailer.
Old 03-01-2017, 07:18 PM   #39
X2
Old 03-01-2017, 08:57 PM   #40
drittal's Avatar
My first response would be that the minimum tow vehicle should be a 3/4 ton diesel truck. At least that is what I would pull a 30 foot Airstream Classic 10,000 pound trailer with...
The excursion is built on F250 chassis. Over 7,000lb empty.
