Old 06-17-2015, 03:54 PM   #11
TURBS's Avatar
Btw the -6 is the upgraded axles but only for cargo carrying capacity only.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-17-2015, 08:39 PM   #12
tdeal823's Avatar
Wow. That golf cart hauler is quite the contraption. I see that more than 1/2 the weight of the cart was on the tail of the frame with that design.
The 32bkok has the bike rack that is rated for 450lbs. Figuring 4 dirtbikes and a small trailer should be under 2200lbs. Standard 10-15% hitch weight I should be about 220-300lbs hitch weight. That would be under the 450 limit of the bike rack.
Are their 5th bunk houses with outside kitchens that allow you to double?
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion or Pullrite 24K, riderite 5000 airbags
2011 Sabre 32BHOK-6 most of the options
tdeal823 is offline   Reply With Quote
Old 06-17-2015, 08:45 PM   #13
B and B's Avatar
Static Load vs active load. Think about the jerking and yawning and bumps that trailer will make with all that weight.
If it could be done I am pretty sure the Manufacturers would market it and sell it.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
hitch, wiring
