Old 06-16-2015, 01:22 PM   #1
tdeal823's Avatar
Double pull hitch and wiring experience
Hello all,
We have a 2011 Sabre 32BHOK-6. We would like to put a 2" receiver on the back and wire for a 2nd trailer. A small one with 3 or 4 dirtbikes on it.
For those that have double pulled would you ever have a need or wanted brakes on the 2nd trailer?
Thanks for the information.
Tony
2008 Silverado 2500HD DMax LTZ cc sb 4x4 EFILive tuned, Blocked, Deleted, Rerouted and removed B&W Turnover ball and 5th Companion or Pullrite 24K, riderite 5000 airbags
2011 Sabre 32BHOK-6 most of the options
tdeal823 is offline   Reply With Quote
Old 06-16-2015, 01:40 PM   #2
clr
I had a 5th wheel mounted on the back of one of my fifth wheels so that I could pull a small fishing boat. As it was under 1500 lbs the boat trailer had no breaks, and I had no problems for years pulling that arrangement. I connected the wiring at the front of the 5th wheel in the forward compartment so that I could get to it easy and then ran it out the bottom of the compartment and along a pipe with zip ties to the rear of the unit worked great for 11 years. By the way I used an ac extension cord and cut the ends off for the wiring to the back, worked great and all within a weather tight cover.
clr is offline   Reply With Quote
Old 06-16-2015, 02:37 PM   #3
B and B's Avatar
I own a Rockwood..
No. Don't require brakes at all. I could not imagine what would happen if the brakes on the dirt bike trailer locked up.
Also you can not tow a trailer behind the Sabre. Other forum members can confirm but this thread speaks to damage that can be caused.
Bent frame on 36 qbok
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 06-16-2015, 02:52 PM   #4
tdeal823's Avatar
Well dang it. The dealership told us that the -6 on the model number was for heavier axles and Springs so we could double tow!
Old 06-17-2015, 01:57 PM   #5
D-maxx dave's Avatar
We did!
Have your dealer install the hitch. Then you're covered. If they won't, perhaps you shouldn't. When we were shopping, we saw many campers with trailer hitches already installed. Pulled a 16' alum bass boat behind a 28' cardinal for years. Lights tied into rv tail lights.
Inexpensive wireless rear camera mounted in rear window.
D-maxx dave is offline   Reply With Quote
Old 06-17-2015, 02:13 PM   #6
tdeal823's Avatar
Not a bad idea. I'll have to call them.
Old 06-17-2015, 03:19 PM   #7
Check your state laws on doubles. Some require a special license.
Harkerr is offline   Reply With Quote
Old 06-17-2015, 03:39 PM   #8
TURBS's Avatar
I have the same unit!
Do not do it.
sabre definitely says do not do it.
Be warned!
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-17-2015, 03:41 PM   #9
TURBS's Avatar
They lied and or don't know any better!
TURBS
2011 32bhok Sabre
Old 06-17-2015, 03:42 PM   #10
TURBS's Avatar
ID:	80286Click image for larger version
ID:	80288Click image for larger version
This is why.
TURBS
2011 32bhok Sabre
hitch, wiring
