Old 04-21-2014, 12:34 PM   #1
Double Towing Capacity
I have a 2008 Rockwood 8244s Fifth Wheel and was wondering if anyone knew if it would be ok to tow a ski boat behind it. I have pulled a bass boat with no problem but the ski boat is about 6000-7000lbs. does anyone know if this would cause any major problems since my camper weighs about the same?
Ace18 is offline   Reply With Quote
Old 04-21-2014, 05:54 PM   #2
bikendan's Avatar
since your frame warranty is expired, it's your call.
but that is an ultralite trailer with an ultralite frame, not designed for what you want to do.
and double towing is illegal in some states.
no way would i do what you're thinking of, with an ultralite trailer, 5th wheel or TT.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-21-2014, 05:58 PM   #3
How could,you even control it in an emergency.
jwedell is offline   Reply With Quote
Old 04-21-2014, 06:04 PM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
Well since you have towed a smaller boat behind the fiver already...means it's doable from a driving stand point BUT adding 6-7 lbs to an ultra light frame, IMO I'd be reluctant...
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 04-21-2014, 08:07 PM   #5
transamz9's Avatar
I agree with others. I tow doubles and my boat is 4500-5000# and I wouldn't do it behind a 5er that is no heavier than what you are towing.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 04-22-2014, 06:15 AM   #6
Incheon, S. Korea
BigBaron's Avatar
What the heck? A 6-7,000 lb. ski boat? That's a BIG boat.
You can do anything if you're willing to do your legwork (and a significant amount of engineering/reinforcing).
You'd need dual brake controllers and a WDH on the boat, plus a significant amount ore-engineering on the trailer frame. Also, you may need to get a special license to tow doubles in some states.
Taking two vehicles is a much simpler option IMHO...
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 04-22-2014, 09:44 PM   #7
Oklahoma Proud
MillerTime's Avatar
Op. We aren't too far from you, in Chandler.
Our boat Is only about 4k or so and has a very heavy tongue, it actually squats my wifes tahoe so we added air shocks.
Anyway, there is no way I would even think for a minute about towing it behind the 5er.
We ALWAYS just take 2 vehicles, I pull the camper, and Dw pulls the boat, unless someone else is headed with us, and they pull the boat.
MillerTime- Future Sabre Handler!!
Old 04-22-2014, 10:07 PM   #8
Lynkage's Avatar
That seems pretty heavy.
I tow doubles but my ATV trailer is #2400 fully loaded and I move stuff around to achieve a 250-300 lb tongue weight.
My fiver is also 13500lbs and I tow with an F450.
It is also the same frame as the big toy haulers and yet I still had an entire sub frame fabricated from the axle hangers back to the end of the trailer frame with 2 X 4" 12 gauge tube and 4 cross-members. Then the 4' receiver tube through 3 of the cross members.
I am not sure I would have more than a 400lb tongue weight back there. I do have brakes on all trailers but the second one is really well behaved and stays true all the time. It is also a tandem axle aluminum ATV trailer so it only weighs 750lbs.
The Ultra-lite frames are just barely good on there own IMO.
This is just food for thought.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 04-23-2014, 12:42 AM   #9
EnduroRdr's Avatar
Saw this guy traveling west on I-12 close to my town.
My guess is he is towing somewhere around 18k maybe even 20k lbs total here. And his truck was a 3/4 ton F250.
That's a lot for that truck. Good thing it is all flat land around here -
Maybe he should get some advice from you guys too?
That is a bit more than I would be comfortable with.
I double tow also, my camper is about 8500-9000 when loaded and the second trailer is under 3000 or less (depends if I pull the utility trailer for cart or 4 wheeler or if I just pull the jet ski which is under 1000lb)
Obviously the guy in this photo is towing about a 12k trailer when loaded with his stuff and 6K to 8K extra load here with that friggin party barge
But even with a light load you will need to re-enforce your hitch to the trailer frame (not the thin wall bumper that holds your sewer line!)
2011 Work & Play 27UL and 2006 Dodge Ram 2500 5.9 Cummins.
EnduroRdr is offline   Reply With Quote
Old 04-23-2014, 12:55 AM   #10
EnduroRdr's Avatar
One nice thing about having a smart phone is, as long as you have your phone you can snap up photos of stuff like this.
Here are a coupe other guys I passed while traveling:
While I went looking for the previous photo I found these from a couple other trips:
And then there was this guy - which maybe also pushing the limits of his equipment. That triple axel Raptor has gotta weigh at least 16K by itself!
It was mentioned earlier about the legality of it. Each state has its own rules so if traveling across lines you have to consider the more restrictive law. Louisiana is 70' total - Mississippi is 99', but I used to live in TX and their website said 65' total counting the tow vehicle for regular driver license. All the states I travel in the south allow triple towing but there are others around the country that don't.
Although I sure see a lot of rigs longer than 70' here in Louisiana. I guess it is not something that officials must be worried about or i live among a bunch of law breakers that done care -
(So using conservative numbers) Obviously 40' Rapture toy hauler and 20 ' boat plus the 18' truck would be over the limit in TX.
Something else to consider!
Anyway I found this interactive site that lists each state rules.
Towing World Official Website
towing
