Old 06-11-2013, 04:11 PM   #11
Big Bad Allis's Avatar
Originally Posted by Big Bad Allis View Post
Tire size is P275/55R20
So assume the "P" rating may be the issue? Also tires are inflated to 35psi and the sidewall states max psi of 44psi. Do you thing I should add a little more psi's? These tires are like new. I hate to buy new LT's but if its a safety concern then I might just have to
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 06-11-2013, 04:14 PM   #12
The P tires are a contributing factor, not enough wt on front and not enough caster are all contributing.
FYI, a 1/4 -1/2 increase in caster over factory specs will do wonders for a wandering problem.
Old 06-11-2013, 04:22 PM   #13
Also they are Goodyear Eagle LS-2
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 06-11-2013, 04:28 PM   #14
Would definitely run them up to max if not to 50# just to try it while towing, especially on the rear and at least 40 on the front for towing. I would let them back down to 35# when not towing as the ride will be horrible.
Old 06-11-2013, 04:29 PM   #15
TURBS's Avatar
I doubt caster is off at 30k but maybe.
Excessive tounge weight resulting in high front end pitch will throw it off tho.
Old 06-11-2013, 04:41 PM   #16
Might not be, I always have them increase caster at least 1/4 over factory. I think on mine it was L +4.10 & R +5.1 and we increased both +.25.
Old 06-11-2013, 04:42 PM   #17
Boy! Dealing with this is going to make me crazy. I never had to worry about with my GMC Sierra with the Duramax.
Thanks again for the help and suggestions
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 06-11-2013, 04:47 PM   #18
Dealing with 2 different animals.
Old 06-11-2013, 04:54 PM   #19
Oaklevel's Avatar
I agree will all the above but also is the hitch set up correctly & is the trailer level (or close ) when it is hitched to the truck. I had a similar issue with my 22' box trailer but it was the hitch set up.
All my issues went away when I got a truck with training wheels
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 06-11-2013, 05:11 PM   #20
Sgt. Schultz's Avatar
The above suggestions to scale is a good idea the ratings on the tire are not the best for towing:
Goodyear*Eagle LS-2
Along with the lower rating when used on an SUV per Tire Tech Information - Tire Specs Explained: Maximum Load :
P-metric tires used on passenger cars and station wagons are rated to carry 100% of the load indicated on the tire's sidewall (or listed for the tire in industry load/inflation charts). However, if the same P-metric tires are used on light trucks, (pickup trucks and sport utility vehicles for example), their carrying capacity is reduced to 91% of the load indicated on the tire's sidewall.
In the mean time I would run them at max sidewall pressure while towing until you can work out the number etc
PT Avenger 33BHS-TE
GMC 2500HD SLE 4x4 Crew Cab 6.0 with 4.10's
Sgt. Schultz is offline   Reply With Quote
