06-11-2013, 02:35 PM
Drift not sway while going down the road
Hello all
Hopefully someone has experience with a similar situation or has a solution. When going 50 - 65 mph it feels like I'm unstable or the TV wants to wander a little while going down the road. I'm using a 2011 Yukon XL Denali and a wildwood 30 ft TT. I have a Reese Dual Cam WD hitch set up. I tried removing some tongue weight and it got worse. Originally I though I was to light in the front end.
Maybe I need more psi in the rear tires of the TV?
Thanks in advance
Jason
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
06-11-2013, 02:36 PM
Few things.
Tounge weight may be to light.
If tires on Denali are p rated tires you better step up to Lt tires.
You may need to scale your tv and rig to find out what's going on.
Should do this anyway!
Turbs
06-11-2013, 03:17 PM
Camper Less Camping
*Check air pressure in TV tires, make sure they are fully inflated
*Check rating of tire sidewall on TV, if they are low ply, you'll get that wandering feeling...move up to stiffer sidewall tires
*From experience, if tire TV tread depth gets too low, when towing camper, TV will wander across road under any conditions...get new tires
*Definitely check that your cargo weight in TT is properly distributed to the front to avoid a very heavy rear end on TT
2013 Sabre 32RCTS-6 (sold)
06-11-2013, 03:40 PM
Might try putting more wt on front, but I would have the front end checked for alignment. Wandering is normally caused by lack of caster.
06-11-2013, 04:02 PM
Front end is solid. Just had it in for the 30k service. It defiantly either weight balance issue or TV tire issue. Please keep the suggestion coming. I really want to figure this out. I will also try to get it on the scales
Thanks again
Jason
2011 Acadia Denali
2014 Montana 356TBF
06-11-2013, 04:05 PM
Thanks again
What is your tire size?
Thanks again
Did they actually check the alignment or just check it for tightness and lube it? Big difference.
06-11-2013, 04:06 PM
Always Learning
What type/size are your tires on the Denali?
And this: "I will also try to get it on the scales." - do that as soon as possible.
(Edit: dang I'm slow.)
06-11-2013, 04:09 PM
Tire size is P275/55R20
Jason
2011 Acadia Denali
2014 Montana 356TBF
About a minute or 60 seconds near as I can tell!
06-11-2013, 04:11 PM
So assume the "P" rating may be the issue? Also tires are inflated to 35psi and the sidewall states max psi of 44psi. Do you thing I should add a little more psi's? These tires are like new. I hate to buy new LT's but if its a safety concern then I might just have to
Jason
2011 Acadia Denali
2014 Montana 356TBF
06-11-2013, 04:14 PM
The P tires are a contributing factor, not enough wt on front and not enough caster are all contributing.
FYI, a 1/4° -1/2° increase in caster over factory specs will do wonders for a wandering problem.
06-11-2013, 04:22 PM
Also they are Goodyear Eagle LS-2
Jason
2011 Acadia Denali
2014 Montana 356TBF
06-11-2013, 04:28 PM
Would definitely run them up to max if not to 50# just to try it while towing, especially on the rear and at least 40 on the front for towing. I would let them back down to 35# when not towing as the ride will be horrible.
06-11-2013, 04:29 PM
I doubt caster is off at 30k but maybe.
Excessive tounge weight resulting in high front end pitch will throw it off tho.
06-11-2013, 04:41 PM
Might not be, I always have them increase caster at least 1/4° over factory. I think on mine it was L +4.10 & R +5.1 and we increased both +.25.
06-11-2013, 04:42 PM
Boy! Dealing with this is going to make me crazy. I never had to worry about with my GMC Sierra with the Duramax.
Thanks again for the help and suggestions
Jason
2011 Acadia Denali
2014 Montana 356TBF
06-11-2013, 04:47 PM
Dealing with 2 different animals.
06-11-2013, 04:54 PM
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
06-11-2013, 05:11 PM
The above suggestions to scale is a good idea the ratings on the tire are not the best for towing:
Goodyear*Eagle LS-2
Along with the lower rating when used on an SUV per Tire Tech Information - Tire Specs Explained: Maximum Load :
P-metric tires used on passenger cars and station wagons are rated to carry 100% of the load indicated on the tire's sidewall (or listed for the tire in industry load/inflation charts). However, if the same P-metric tires are used on light trucks, (pickup trucks and sport utility vehicles for example), their carrying capacity is reduced to 91% of the load indicated on the tire's sidewall.
In the mean time I would run them at max sidewall pressure while towing until you can work out the number etc
PT Avenger 33BHS-TE
2020 f-250
