Old 06-11-2013, 02:35 PM   #1
Big Bad Allis's Avatar
Drift not sway while going down the road
Hello all
Hopefully someone has experience with a similar situation or has a solution. When going 50 - 65 mph it feels like I'm unstable or the TV wants to wander a little while going down the road. I'm using a 2011 Yukon XL Denali and a wildwood 30 ft TT. I have a Reese Dual Cam WD hitch set up. I tried removing some tongue weight and it got worse. Originally I though I was to light in the front end.
Maybe I need more psi in the rear tires of the TV?
Thanks in advance
Jason
Jason
2012 F350 SRW Powerstroke
2011 Acadia Denali
2014 Montana 356TBF
Big Bad Allis is offline   Reply With Quote
Old 06-11-2013, 02:36 PM   #2
TURBS's Avatar
Few things.
Tounge weight may be to light.
If tires on Denali are p rated tires you better step up to Lt tires.
You may need to scale your tv and rig to find out what's going on.
Should do this anyway!
Turbs
Old 06-11-2013, 03:17 PM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
*Check air pressure in TV tires, make sure they are fully inflated
*Check rating of tire sidewall on TV, if they are low ply, you'll get that wandering feeling...move up to stiffer sidewall tires
*From experience, if tire TV tread depth gets too low, when towing camper, TV will wander across road under any conditions...get new tires
*Definitely check that your cargo weight in TT is properly distributed to the front to avoid a very heavy rear end on TT
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-11-2013, 03:40 PM   #4
Might try putting more wt on front, but I would have the front end checked for alignment. Wandering is normally caused by lack of caster.
Old 06-11-2013, 04:02 PM   #5
Front end is solid. Just had it in for the 30k service. It defiantly either weight balance issue or TV tire issue. Please keep the suggestion coming. I really want to figure this out. I will also try to get it on the scales
Thanks again
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 06-11-2013, 04:05 PM   #6
TURBS's Avatar
Thanks again
What is your tire size?
Old 06-11-2013, 04:05 PM   #7
Thanks again
Did they actually check the alignment or just check it for tightness and lube it? Big difference.
Old 06-11-2013, 04:06 PM   #8
Fulltime family RVer
What type/size are your tires on the Denali?
And this: "I will also try to get it on the scales." - do that as soon as possible.
(Edit: dang I'm slow.)
ependydad is online now   Reply With Quote
Old 06-11-2013, 04:09 PM   #9
Tire size is P275/55R20
Jason
2011 Acadia Denali
2014 Montana 356TBF
Old 06-11-2013, 04:09 PM   #10
TURBS's Avatar
About a minute or 60 seconds near as I can tell!
