Old 06-13-2014, 08:09 AM   #41
Kaadk's Avatar
Originally Posted by N3HCP View Post
Interesting. I have tried to find any specific information on licensing reciprocity between the US and Canada and specifically Ontario, no luck.
Hard to believe Ontario would pass up all those tourist bucks and that RVers would need to go back into the States to go from Quebec to Manitoba.
Right from the MTO:
Driver licence reciprocity
Ontario permits an out-of-province driver to drive a vehicle or combination of vehicles in Ontario if the driver is properly licensed to drive the vehicle or combination in their Province or State of residency and the licence is valid.
Information found here: RV Information for Drivers - Class of driver's licence
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 06-13-2014, 08:12 AM   #42
Ford Idaho's Avatar
An RV in most cases in NOT a Commercial Vehicle.
CDL.
https://www.google.com/#q=+CDL
A commercial driver's license (CDL) is a driver's license required in the United States to operate any type of vehicle weighing more than 26,000 lb (11,793 kg) or more for commercial use, or transports quantities of hazardous materials that require warning placards under Department of Transportation regulations, or that is designed to transport 16 or more passengers, including the driver. This includes, but is not limited to, tow trucks, tractor trailers, and buses.[1]
The Commercial Motor Vehicle Safety Act of 1986 was signed into law on October 27, 1986. The primary intent of the Act was to improve highway safety by ensuring that truck drivers and drivers of tractor trailers and buses are qualified to drive Commercial Motor Vehicles (CMVs), and to remove drivers that are unsafe and unqualified from the highways. The Act continued to give states the right to issue CDLs, but the federal government established minimum requirements that must be met when issuing a CDL.[2]
Old 06-13-2014, 08:27 AM   #43
DaveSchwartz's Avatar
Was not hard to find... Licence Types, follow the link under the class G change and look at Q2 of the FAQ. Reciprosity works both ways: if you are properly licenced in you home state/province you are legal here.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 06-13-2014, 09:48 AM   #44
N3HCP's Avatar
So to summarize what we've learned, Pennsylvania, along with about 14 other states, require something beyond the normal driver's license when the combined GVW (that is the GVW found on the manufactures plate) exceeds 26,000 pounds. Only DC requires a CDL for such vehicles while a few others require it for vehicles longer then 45 feet. In PA that is a Class A license instead of the normal Class C.
I have found no instances where a state or province does not honor my PA license as long as I'm legal in my home state.
So our F-350 at 14,000 pounds and our Surveyor at 11,952 pounds means I'm under the weight allowed by my Class C license by 48 pounds!
2013 F-350 Diesel Dually, 6.7L with 3.73 rear with 50 gallon Transfer Flow aux fuel tank, ScanGauge II, Tire Minder on all 10 tires, 2M ham radio, and the ever popular CB.
2014 Surveyor SVF-293RLTS
2014 Clipper 16FB
N3HCP is offline   Reply With Quote
Old 06-13-2014, 03:46 PM   #45
prof_fate's Avatar
Originally Posted by bagged123 View Post
your fine, your not using your rig for commercial use. When someone can go buy a motor coach with air brakes and don't need an air brake endorsement, then no special endorsements are needed (as of yet) for towing a TT, 5'er, etc. I know someone that owns a KW that he uses to tow his 5'er with and due to its private use, all he had to do was put 'not for hire' on the side of it and he's fine. He replaced the factory 5th wheel plate with a smaller one for his 5'er.
(note: at the end of the day, it comes down to your state)
I've seen 'not for hire' on quite a number of commercial trucks and thought when it said 'lowes' or something on it that it was stupid to say 'not for hire' as it was obvious...but now I see there is a reason for it.
I've driven a few trucks with air brakes, not often, with previous employers, and nobody ever said anything about anything.
As for PA (or any gov't office) not know their own rules, it's common. I've had the experience with penndot myself and with post offices on a regular basis.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 06-13-2014, 03:49 PM   #46
prof_fate's Avatar
Originally Posted by wnytaxman View Post
If you have any doubt that you should make the effort to be legal, then just turn on your TV and see how many attorneys are out there soliciting lawsuits. If you've ever had to appear in a courtroom you know that attorneys will twist things into a way that will cost you mucho $$$$. Be safe.
Exactly. We're in court in a few weeks for something stupid. Our dog ran to the end of our yard, a car stopped fearing the dog would run into the road. They got rearended and are suing US! Really? They chose to stop and someone hit them...how is that possibly our fault?
Been over 3 1/2 years in the making now...fortunately our homeowners insurance cover this, so far with no deductible from us.
2011 Grey Wolf 28BH
Old 06-13-2014, 03:57 PM   #47
CLT
Next Gen Camperbot 5000XL
CLT's Avatar
Wow, so when a squirrel or a stray cat does the same thing then what happens? This is crazy!
NO TV!!! NOW WHAT???
2014 Coachmen Apex 259BHSS
CLT is offline   Reply With Quote
Old 06-13-2014, 04:16 PM   #48
Who Dares, Wins
doc73's Avatar
Squish is what happens....
As for the not for hire it does depend on how the veh is being used in pa. A vehicle like a tow truck for instance is required to have certain info on it by law. If it is a private hauler only (tows a race car lets say) the not for hire allows them to skip the required labeling. You'll see the same on the large enclosed car carriers and such that haul private vehicle's.
Sent from my SAMSUNG-SGH-I747 using Forest River Forums mobile app
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-13-2014, 04:21 PM   #49
prof_fate's Avatar
I was told long ago hit the critter - swerving and hitting say, a tree or fence and the critter runs off and guess what? Reckless driving, loss of control..no insurance for that one. But if you have collision then a deer/dog crash is covered.
Our lawyer says PA law is quite clear - you must be in control of your vehicle at all times. You rear end someone and you pay - period, no discussion. I experienced that in college when a guy behind me got all irate with road rage (not called that then) - so I stopped in the middle of the road. He stopped just shy of my truck. Guy behind him, however, didn't stop. That guy in the back paid everyone. No tickets or nothig for me.
But as they say, you can sue anyone for any reason - winning is a separate issue.
2011 Grey Wolf 28BH
Old 06-17-2014, 08:37 AM   #50
Perhaps this link can be helpful.
RV Driver's License Requirements
I just took and passed my NYS driving test for my 'R' endorsement. The test was easy and not a big hassle at all. If you have any doubt that you should make the effort to be legal, then just turn on your TV and see how many attorneys are out there soliciting lawsuits. If you've ever had to appear in a courtroom you know that attorneys will twist things into a way that will cost you mucho $$$$. Be safe.
Excellent reference taxman. The dept. Trained you well.
