Closed Thread
Old 05-08-2013, 10:35 AM   #31
Fulltime family RVer
Originally Posted by ATsXLR View Post
Ependydad,
I take it you have a Blue Ox bed-saver installed?
I've been looking for "protection" myself, but I've installed a Curt Q20 hitch and Butch doesn't have anything as yet (due to the punched head design, I'd presume). Over-all are you confident with it's design. Hate to ask, but have you had to use it?
Thanks again-
I actually do not have either. And, guess I should advertise that better.
I don't have the Blue Ox due to the weight and making the coupler more unwieldy for installing and removing the hitch (I do it on a fairly regular basis when we need the full truck bed). But, in theory (and from reading of people who have used it) - I am confident of the design. Like I've harped on - I like that it's always engaged and ready to catch a drop.
I don't have the Butch's catcher due to not agreeing with the fundamentals of the design. If my attention was taken away and I missed a step, I don't see why this wouldn't or couldn't be one of the steps.
ependydad is offline
Old 05-08-2013, 11:01 AM   #32
Thanks Ependydad for the clarification. I too like the Blue Ox design intent and also have grief with the additional weight, as it is I have a fun time breaking loose the rubber bond from the head to the carrier body after the silicone dries out, now add 40 additional pounds.
I'm going to give Butch a shout to see what's available (thanks OldCoot!).
Tony & Dari-
2014 XLR Thunderbolt 300x12
2012 Ram 2500 Longhorn Mega CTD
ATsXLR is offline
Old 05-08-2013, 11:04 AM   #33
treaves's Avatar
When looking at hitches for my truck, "hitch malfunction" couldn't have happened with the units I looked at, as they are designed to mechanically prevent this. If the hitch is used as designed, the locks would prevent the kingpin from coming loose. I'd be surprised if there were hitches sold that were not this way.
A component failure could of course cause it, but then there is obvious evidence (in the failed component).
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline
Old 05-08-2013, 11:15 AM   #34
I've heard Butch is good to work with and may help fabricate something specific for your hitch.
Old 05-08-2013, 11:26 AM   #35
There are ways to modify things to make sure you do what is required, like attaching the emergency brake cable to the rod on the hitch catcher so that to secure the cable, you have to insert the rod.
OldCoot is offline
Old 05-08-2013, 11:58 AM   #36
Just another example of why I bought the 'slide-bar' type of hitch.
There is no way to hook up wrong, and once that bar slams into position behind the pin, it ain't goin nowhere.
Simple, and foolproof.
bakken is offline
Old 05-08-2013, 12:06 PM   #37
My Reese also has a positive lock that must be seated to flip the lock bar over the handle, but I also added my version of Butch's catch just in case something breaks. Everything is mechanical and mechanical things break.
OldCoot is offline
Old 05-08-2013, 12:11 PM   #38
TURBS's Avatar
In you theory you should have a hitch catcher behind the hitch catcher then ?
TURBS is offline
Old 05-08-2013, 12:13 PM   #39
B47
Yeah that will work - just makes you perform another step to make sure you are latched up
B47 is offline
Old 05-08-2013, 12:13 PM   #40
I'd be willing to be that far more dropped fivers are user error than mechanical failure. Someone missed a step somewhere...
For my B&W hitch, you can't close the handle if you're not hitched properly. It just can't be done- it is impossible. But, over on RV.net, someone with a B&W hitch dropped his fiver because he forgot to close the handle (worse, he followed instructions and previously pinned the handle in the open position).
Things happen.
The Butch's catcher gives you an element of protection against that. I just personally think while it's 5-times the cost that the Blue Ox product gives you more.
Closed Thread
