09-24-2015, 11:38 AM
#21
My ford had this option or a heavier duty one I chose the heavier duty. The second one is for the 2nd battery and that battery is for the trailer or a camper. Mine still came with the two batteries as the RV equipment package.
09-24-2015, 11:40 AM
#22
Gm ' s second battery option "non diesel "
Was only wired to the "rv" harness between cab and box.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
09-24-2015, 01:31 PM
#23
Global Nomad
dual alternators or heavy duty
I am in the process of picking out a truck to pull my new Cedar Creek, weighing in at 16,500 lbs. It appears the dual alternators will charge my 4 6volts better than a heavy duty alternator while I am traveling.
09-24-2015, 01:33 PM
#24
TURBS
2011 32bhok Sabre
You really do not need two alternators what you need is a larger one with more amps. I had a 70 amp alternator and 4 d-8 batteries in my sail boat. It would take over 3 hours of engine time daily to make them reach capacity on a sail boat. I put in a 150 amp alternator and charged my batteries full in an hour of run time. In turn I used 1 gal of diesel compared to 3 gals for the same charge to carry me through for 24 hrs with an inverter I was running 24 hrs a day for navigation with a computer at 110v and 12 v for the refer and water maker daily. It was the highest output at that time for the marine industry bought at West Marine. When you only have a 50 gal tank you learn other way's to conserve. This was all designed by a marine engineer with the tacking solar panel system. The solar system at that time would only put out 4 amps ( should have went with a wind generator hind site as always)
Coachmen M/H
Concord
2018 / 300 DSC
09-24-2015, 02:43 PM
#25
How many amp's is the HD compared to the 2 standard?
Coachmen M/H
Concord
2018 / 300 DSC
09-24-2015, 02:48 PM
#26
I would get duals over hd single.
Also, that's max amps.
You don't get that at idle.
2008 F350 CCSB V10
2016 Sabre 36QBOK
2017 Dynamax Isata 4
09-24-2015, 03:50 PM
#27
These are for vehicles with extreme electrical needs... light bars, strobes, spot lights, and so on. A lot of vehicles that have them are bought by road construction companies, fire departments, railroads, etc, with a lot of lighting needs and/or with large inverters for running power tools and equipment. RVers really don't need them for the most part. My field manager job with the railroad involved installing electrical equipment in company vehicles, and many of them had dual alternators.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
09-24-2015, 05:37 PM
#28
Thanks everyone - so, it seems like they are used for with the plow prep package and commercial uses, but not so much in an RV application.
09-24-2015, 05:48 PM
#29
Phat Phrog Stunt Crew
My 2014 GMC comes standard with a 125 amp alternator and the snowplow pkg has two 125 amp to supply the electric snowplow, over head flashing lights & back up lights. In my world, plowing in the dark consumes a lot of power. The 2016 GMC now has 220 amp alternator for the snowplow pkg.
Ambulances also need a ton of power and use large alternators to maintain lights and equipment. A RV doesn't need the 200-300 amps of power to function.
2014 Wildcat 327ck
09-24-2015, 06:07 PM
#30
Just did some checking in the 2013 Super Duty Pickup Dealers manual I have. With the Snowplow Prep Package you get an extra-heavy-duty alternator (200 amp) with the 6.7L Power Stroke diesel engine or heavy-duty alternator (157 amp) with gasoline engine. Minimum required equipment for Snowplow Package includes 157 amp, heavy-duty alternator (6.2L). Optional: Dual alternators 357 amp (6.7L diesel). This is what Ford says.................
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
09-24-2015, 06:16 PM
#31
Originally Posted by esloser
Besides the more is better argument, is there any specific benefit it would provide? Can it be used to charge batteries on travel trailer faster than the standard 7 pin connection?
Dualies with a camper on their back need the juice for charging the house batteries.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
09-24-2015, 06:23 PM
#32
If I'm not mistaken I believe that the Rapid-Heat Supplemental Cab Heater requires a upgrade alternator since it has electric heating element that comes on before the engine warms up. By the way I have a diesel and I have cabin heat before I can back out of the garage.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
09-24-2015, 07:06 PM
#33
My 2015 2500HD Duramax w/ snow plow package has the mandatory dual batteries and an HD alternator ( only one). In addition, unless a very heavy wire is run from the engine compartment to the 7 pin Bargman ( not the OEM wire) , it doesn't matter how many alternators you have. If you are drawing 20 amps on that cable you will get enough voltage drop to make it difficult to charge the RV battery no matter how many amps are available.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
09-24-2015, 08:22 PM
#34
Bob
You only missed one part. Lariat and up models got the 200A standard. I elected to just leave mine with the standard 200A. Less weight and I don't have a large electrical demand. I do not have the plow package on mine either. Salesman thought I was nuts because it's only $85, but every dually I saw with the plow package sat nose up with minimal weight in the bed, and I didn't want that.
I think Flybob nailed it, there's really no gain going back to the RV with the factory wiring. If duals makes you feel better go for it, but I don't see the need. Now most of the additional lighting being added to trucks is LED anyway and they pull a lot less amps than the old incandescent stuff.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
