Old 09-24-2015, 06:16 PM   #31
Herk7769's Avatar
Originally Posted by esloser View Post
Besides the more is better argument, is there any specific benefit it would provide? Can it be used to charge batteries on travel trailer faster than the standard 7 pin connection?
Dualies with a camper on their back need the juice for charging the house batteries.
HAM CALLSIGN - KC3FFW
Old 09-24-2015, 06:23 PM   #32
CWSWine's Avatar
If I'm not mistaken I believe that the Rapid-Heat Supplemental Cab Heater requires a upgrade alternator since it has electric heating element that comes on before the engine warms up. By the way I have a diesel and I have cabin heat before I can back out of the garage.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 09-24-2015, 07:06 PM   #33
Flybob's Avatar
My 2015 2500HD Duramax w/ snow plow package has the mandatory dual batteries and an HD alternator ( only one). In addition, unless a very heavy wire is run from the engine compartment to the 7 pin Bargman ( not the OEM wire) , it doesn't matter how many alternators you have. If you are drawing 20 amps on that cable you will get enough voltage drop to make it difficult to charge the RV battery no matter how many amps are available.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-24-2015, 08:22 PM   #34
ferguson65's Avatar
Originally Posted by retiredcamper47 View Post
Just did some checking in the 2013 Super Duty Pickup Dealers manual I have. With the Snowplow Prep Package you get an extra-heavy-duty alternator (200 amp) with the 6.7L Power Stroke diesel engine or heavy-duty alternator (157 amp) with gasoline engine. Minimum required equipment for Snowplow Package includes 157 amp, heavy-duty alternator (6.2L). Optional: Dual alternators 357 amp (6.7L diesel). This is what Ford says.................
Bob
You only missed one part. Lariat and up models got the 200A standard. I elected to just leave mine with the standard 200A. Less weight and I don't have a large electrical demand. I do not have the plow package on mine either. Salesman thought I was nuts because it's only $85, but every dually I saw with the plow package sat nose up with minimal weight in the bed, and I didn't want that.
I think Flybob nailed it, there's really no gain going back to the RV with the factory wiring. If duals makes you feel better go for it, but I don't see the need. Now most of the additional lighting being added to trucks is LED anyway and they pull a lot less amps than the old incandescent stuff.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
