Old 05-24-2016, 07:11 AM   #1
muddyrode's Avatar
Dual Tire Pressure Equalization System
So is anybody using a Dual Tire Pressure Equalization System?
and if so what brand are you using?
looking for a better way for my dually, as trying to check the pressure on the rear tires is a pain
thanks
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 05-24-2016, 08:24 AM   #2
Fulltime family RVer
I debated these for a while but ultimately ended with the feeling that I didn't put enough miles on the truck to justify it.
Instead, I opted for a TPMS from TST so that I can know what all 6 truck tires are at a glance.
When it's time to air up the tires, I use a straight dual-head air chuck and the same for a digital tire pressure gauge (straight dual-head).
The biggest thing- when I have the tires rotated or any shop does work to remove the wheels, I make sure to tell them to ensure that the inner dual valve stem lines up with a hole in the rim so that my tools reach through.
Old 05-24-2016, 08:58 AM   #3
SKnight's Avatar
As a career mechanic I find it sad you need to tell them that. Hang the first tire, it takes literally no time to set the outer valve stem opposite the inner valve stem and hang the outer wheel.
Old 05-24-2016, 09:00 AM   #4
You know what they say about signs and warnings... they're there for a reason.
That one or two times that I didn't, I paid the price for it.
Old 05-24-2016, 09:17 AM   #5
Commercial Member
thanks
As a tire engineer I see little to no advantage and some definite downside with the tire equalization gizmos.
If/when you get a puncture or leak in one tire BOTH tires will have the air pressure reduced till the limit is reached then one tire will continue to leak. Now you have an underinflated tire being 100% overloaded. This can lead to damage that may result on both tires ultimately failing.
The gizmos do not provide timely warning. You can still drive hundreds of miles before you stop and check tire inflation. At that point it is too late. BOTH tires will be scrap.
TPMS will provide timely warning to the driver on low air pressure.
If you are having problems getting to your valves to inflate or install TPMS simply use the appropriate hose extenders with the outer end firmly attached (pop rivet) as seen below.
When inflating tires be sure to support the hose when pressing the air chuck to end of hose so not to over stress the rivets or hose mount.
I have over 30k miles on above and similar with no problems.
I got my hoses on Amazon.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 05-24-2016, 11:35 AM   #6
Do you have a recommendation on TPMS system for dual wheel trailer? They don't interfere with vehicle system or navigation system wifi, do they? We have a 2011 Wildwood and just bought a 2016 Ford F150 4x4 Lariat. Thanks in advance for any tips!
wildwoodtraveler is offline   Reply With Quote
Old 05-24-2016, 11:48 AM   #7
dieselguy's Avatar
In my experience of several years running a dually, the tire equilization accessory defeats one of the advantages of duals. If one goes flat ... they both will. On two occasions I had one of the duals go flat ... one due to a valve stem and one a screw. I was able to continue on at a reduced speed to a more convenient place to fix the flat. If I had had the equilizers added I would have been sitting right where it all started and neither place was pretty.
dieselguy is offline   Reply With Quote
Old 05-24-2016, 12:04 PM   #8
Commercial Member
I bought a TPMS back before I started writing my blog. I have Tire Trakker and like the Lifetime warranty, user replaceable sensor batteries. Battery operated monitor and especially the Early warning from the "Rapid" air loss.
Full disclosure. They sponsor the blog I write, but since I do not own the blog (I write for the blog owner RVTravel.com) I receive zero income and no commission from any sponsorship or sales of TPMS.
I do have a post on "Best TPMS" where I identify the features I think should be considered before purchase. There is no single brand or type TPMS that is "Best" for everyone as we all have different wants and needs.
Old 05-24-2016, 03:23 PM   #9
It's Tire Traker.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-24-2016, 08:11 PM   #10
RudysWorld's Avatar
I use crossfire, when tire pressure drops 10 psi valve closes so both tires don't go flat as some people have stated earlier. After the numerous posts where people with TPMS had blowouts with out warning I thought the extra money was not worth it IMHO. To each their own, I have only had them on for 6 months so no long term experience yet. Good Luck!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
pressure, tire
