Old 10-12-2015, 10:44 PM   #1
Duramax ??
I just purchased a 07 LMM and it seems to idle high. What is the normal idle rpm of these engines?
mfMcFroggierPod is offline   Reply With Quote
Old 10-12-2015, 11:10 PM   #2
Oklahoma Proud
MillerTime's Avatar
What are your rpms at? I've heard that they should be about 720 but i would have to look at my scanner and see for sure. I've heard some guys uping the idle to 765 and some lowering it to 680 and 650.
I know the 2011 and up dmax will idle higher than that to warm up like the 800-900 range but will drop when you hit the brake to place in gear and i find mine will idle up while parked after I've driven it a while, im assuming to help cool it down. ( and im not talking about the actual high idle switch being engaged that is used for cold weather ).
I haven't had that generation of the duramax motor but ive had the 2nd gen (2005) and the current (interim 2015 ).
Higher idles are actually safer than low idles on bigger engines' bearings from what I've heard.
Sorry if this doesn't help much.
Old 10-12-2015, 11:14 PM   #3
Thank You
I guess it's normal than ...
I am seeing 720-750 idle in drive, it just seemed high compared to my gasser
Love the Power
Old 10-12-2015, 11:39 PM   #4
Alberta8311ss's Avatar
That's right, mine is the same 750 ish.
2014 Rockwood 8311SS
Alberta8311ss is offline   Reply With Quote
Old 10-13-2015, 04:45 AM   #5
We have a 2015 duramax, idles right around 750 or so.
traysurfer is offline   Reply With Quote
Old 10-13-2015, 06:50 PM   #6
Computer Nerd's Avatar
I have 2014 Duramax and I agree with the 750 RPM idle. The only time it increases is when its first started and when the diesel particulate filter is being flushed.
Computer Nerd
2014 Chevy Silverado 3500 HD Duramax
2016 Sandpiper 35ROK
Computer Nerd is offline   Reply With Quote
