Old 07-07-2015, 06:11 PM   #31
Reduced power
Same problem last year with 2015 finally replaced. The valve that fixed Carl Chevy Ankeny is fixed
sbelan is offline   Reply With Quote
Old 07-07-2015, 06:31 PM   #32
Fuel Filter
Look at % good for fuel filter. I suspect it is dead or near dead. Had the same problem towing up a mountain pass. Left home with 60% life remaining on fuel filter. Suspect I got some bad fuel at a station out in the boonies of Wyoming. Limped back downhill after leaving the 5th wheel by the road and found a guy in Lander, Wy to change the fuel filter and life is now good. Drover thought that pass today at 60 mph; much better than 5mph.
Good luck. With a diesel; it is usually the fuel.
Waynedeer is offline   Reply With Quote
Old 07-07-2015, 11:06 PM   #33
I had the same problem with my 2004 GMC. Fortunatly, the first time it happened in the mountains about 500 miles from home, I had a code reader that I used to reset the ECM. I kept the rpms down and made it to the campground and then home again. I changed the fuel filter and the problem was solved.
Do yourself a favor and either get a code reader that will allow you to reset or cancel the error codes or get yourself a tuner that will do the same thing. I got a tuner that puts the ECM into "TOW MODE" which adds a few horses to the engine and tunes the transmission for better towing. I always keep the truck in this mode and have never had a problem.
Reb Kitt is offline   Reply With Quote
Old 07-07-2015, 11:06 PM   #34
Replace the fuel filter housing. If you have to re-prime, its likely an air leak. I had a similar problem with my LBZ except mine was towing a grade. If you decide to replace the housing, check around on prices.
fvstringpicker is offline   Reply With Quote
Old 07-07-2015, 11:15 PM   #35
mike.t's Avatar
Great. What was the code?
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 07-08-2015, 07:05 AM   #36
satdog01's Avatar
Had the same issue with my 2007. Turned out I had gotten bad fuel on the back roads of LA. Replaced fuel filter and "O" rings that come with most fuel filters. Fixed issue, always travel with spare fuel filter, learned quickly most auto supply places do not stock these filters. Was fortunate the O'Rileys did but at a higher pric. Got me back on the road, so extra price was worth it when you are 300 miles from home. Not the biggest fan of Amazon, but they do carry filter at a good price.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 204 nights as camping buddy
Days camped in FR, 2011 = 20, 2012 = 57, 2013 = 59
....2014 = 39, ‘15 = 52, ‘16 = 77, ‘17 = 81, 2018 = 4
Retired :
satdog01 is offline   Reply With Quote
Old 07-08-2015, 08:06 PM   #37
Tonkatoy77's Avatar
Did you ever get the code out of your truck? I am going to guess P0087. Low fuel rail pressure. There is a lot of things that can cause this code. The most popular are: bad fuel pressure regulator, plugged fuel filter, bad fuel filter head, bad water in fuel sensor, and bad fuel lines between fuel filter and CP3. A bad CP3 can also cause this code, but that is the last thing I would check because it is the most expensive.
The Duramax engine does not have a fuel lift pump. It is highly recommended that all Duramax owners add one.
2007 Chevy Duramax EFI Live and other supporting mods.
2015 Wildcat Maxx T26BHS
Nights camped 2015....23
Tonkatoy77 is offline   Reply With Quote
Old 07-08-2015, 08:38 PM   #38
mike.t's Avatar
Seam's people ask for help but when someone replies with a question (ie what was the code) they don't reply.??
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 07-08-2015, 11:03 PM   #39
So agreed to that mike.t people throw a question or problem with no or little information and no follow up.
jimmyt11664 is offline   Reply With Quote
Old 07-09-2015, 11:45 AM   #40
mike.t's Avatar
jimmy. There was another topic about something the OP needed help with.As usual there were many replies from the FR group and nothing from the OP. I finally said to him if you got it fixed with the help of someone here please thank them. He got back and said something like i found the lens thanks. Losers!!
2015 Salem 27RKSS
55' Chevy Bel-Air
diesel, power
