10-22-2018, 08:09 AM
Duramax engine oil
What is normal oil loss between oil changes? My Silverado has 150,000 miles and a lot of the miles towing a camper. I have noticed on the last few oil changes that I’m losing a quart of oil. Is this normal?
10-22-2018, 08:12 AM
What milage schedule are you on for oil changes
Retired Navy
2016 Flagstaff 26 FKWS
10-22-2018, 08:14 AM
I just use what the truck says. I use synthetic oil
10-22-2018, 08:22 AM
Sea Dog means at how many miles after an oil change are you finding it a quart low? 3000 miles? 8000 miles?
10-22-2018, 08:36 AM
Er, no he doesn’t. He clearly asked what his oil change interval is.
To the OP, you must have some idea of how often the truck says it’s time to change the oil. A quart isn’t out of spec unless it’s every couple thousand miles or so. A quart after 6000-7000 miles isn’t a problem especially considering your truck holds what, 15 quarts or so?
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
10-22-2018, 08:51 AM
My Silverado holds ten quarts. To be honest I haven’t really checked how many miles I go between oil changes, I just go with whenever the meter says change the oil on the truck.
10-22-2018, 08:55 AM
How often I change the oil is not what I wanted to know. I was asking if it was normal after 150,000 miles on the engine, was to normal to lose a quart of oil between changes. That’s what I wanted to know
10-22-2018, 09:01 AM
I was referring to SeaDog’s question and the apparent confusion someone had with it.
2013 Shamrock 21SS
10-22-2018, 09:03 AM
Not knowing how or when the computer on your truck signals the oil change. by particulate contact or miles it is almost impossible to answer your question. Like was said if you are putting on more then six thousand miles to a change that would seem normal. You do check the oil when you get fuel right, so there should be no surprises.
Retired Navy
10-22-2018, 09:10 AM
You missed my question. I deleted the emissions on my truck. I just wanted to know on a engine that had a 150,000 miles was it normal to lose a quart of oil between changes. If you have no idea or don’t know don’t answer.
10-22-2018, 09:13 AM
Dude, without knowing HOW MANY MILES between oil changes how do you expect anyone to know if it’s normal?
A quart every 5,000-6,000 miles is normal, especially if towing. Also, make sure you’re checking the oil level after the truck has sat for at least 20 mins or overnight to give the oil time to drain back into the pan.
2013 Shamrock 21SS
10-22-2018, 09:20 AM
easy answer yes
Retired Navy
10-22-2018, 09:28 AM
If you are concerned about the health of the engine, I would do a couple of oil samples and send them to a qualified lab. What this will tell you if there are any abnormal wear issues and contaminates in your engine oil. Such as excess diesel fuel, Silicon, Sodium and than wear metals like Iron, Nickel, Aluminum, to name a few things. Oil consumption is a normal process over time and mileage but some engines may burn more oil than others as they age. The rings will wear and the cylinder walls could wear also. High metal contaminates could be telling you that the engine is starting to wear as it ages (high mileage) and oil blow by could occur. Since you have a diesel the engine will burn this oil blow by away in the combustion process.
I would not rely on an engine computer to tell me when to change the oil/filter on any truck. I would go by the manual in your truck that will list oil change intervals based on time and mileage and heavy towing or not. Or I would use a lab recommendation like I do, as to when to change the oil/filter. The engine ECM is not monitoring the oil quality, it is purely a logarithm that an anyslist programmed into the ECM to tell you when to change the oil based on time.
Just my $0.02
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 145K+miles
10-22-2018, 09:42 AM
Yes it is normal to use a quart of oil between oil changes. Never mind whether high mileage or not. Doesn't really matter the make of the engine either. Don't worry this is not a sign that your engine is going to 'Crater' any time soon.
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Illegitimum non carborundum
10-22-2018, 09:51 AM
If you lose a quart at 1000-2000 miles....you've got a problem. If you lose a quart every 5-6000 miles, no big deal. This isn't rocket science.
10-22-2018, 10:11 AM
Oil use is normal in ANY modern engine and as they age they tend to use more oil as the clearances open up. The oil change interval question was appropriate. Using a quart every 3000 miles is a lot more oil use than using a quart every 10,000 miles.
Many manufacturers went to 0W-20 engine oil for better fuel economy. This thin oil tends to be "used" in the engine more than (say) 10W-30 and is normal.
Regardless the oil level need only be somewhere between the marks on the dipstick. Not necessary to have it at the top mark (but it shouldn't be over).
-- Chuck
10-22-2018, 10:14 AM
Insert witty title here
x2
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
10-22-2018, 10:46 AM
My 2007 LBZ Duramax has 150,000 miles. It is a daily driver. I change the oil every 5k. Non-synthetic. I don't trust the dic to tell me when to do it. If I am towing, it is normal to use 1 quart, or a little more, in 5k. So when I am towing frequently, I change the oil at 3 to 4k. When not towing, no, it doesn't use enough oil to notice in 5000 miles. But yes, In general, all diesels use oil during operation. The amount depends on severity of use and engine condition. Does this help?
If you are going by the computer for oil change intervals, I'm assuming the interval is closer to 10k. So one quart of usage should be of no concern.
The Duramax Diesel forum has lots more info on this that might interest you.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
10-22-2018, 12:02 PM
This was my point in my post above. Since you do not track the miles between changes it is difficult to say whether your oil consumption is excessive.
Bottom line, 1 quart usage at the indicated change interval is not excessive. If it increases to two quarts, you have an engine that is wearing out.
10-22-2018, 04:46 PM
Once I get back home I’ll change the oil and write the mileage down. I’m taking truck back to the shop that did the delete on the Silverado to flush the transmission and flush the antifreeze. I’ll ask them. Thanks for the advice
