Old 01-01-2015, 03:05 PM   #1
Retired
RubyDually's Avatar
Duramax fuel filter access door
For the Duramax owners who prefer to change their fuel filters themselves....
In my last 2010 LMM I could change the filter with a bit of swearing from the top but now my 2014 LML I can't change it from above.
The truck has mud flaps on it so to remove the inner fender the right mud flap would also have to come off so.... instead I installed a fuel filter access door which I bought online along with some extra fuel filters.
I gotta say with the access door it really makes changing the filter easy peasy without any swearing at all.... Ten minutes max...
Way better than the $180.00 the dealer want around here to do it! Maybe that's the reason why these trucks don't come with an access from the factory!
Name:	fuel filter access.jpg
ID:	68029   Click image for larger version
Name:	fuel filter access door.jpg
2014 Chevrolet Silverado 3500 LTZ CCLB DRW D/A - Rancher Grille Guard - Transfer flow 40 gallon Toolbox/Tank Combo - Line X - Edge Insight
2015 Palomino Sabre 33CKTS - Platinum Edition - Progressive Industries EMS HW50C - JT Strong Arm Stabilizers - Ground Control 3.0 - 320 Watt Solar with 2000 Watt Inverter
RubyDually is offline   Reply With Quote
Old 01-01-2015, 06:30 PM   #2
I jus installed a FASS 150 which includes a crew on fuel filter and water separator. Takes about 1 minute to sap out the filters as it is on the frame rail underneath the cab. Mine also has the lift pump so I can feed the CP4 under the hood and reduce stress on that thing.
If I didn't want the lift pump, I would have done the access door.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
door
