Old 02-11-2014, 09:39 AM   #1
TURBS's Avatar
Duramax fuel filter adapter "nicktane"
Has anyone added the adapter to the stock duramax fuel filter assy. To be able to run the 1 and 2 micron caterpillar filters?
Duramax Catepillar Fuel Filter Adapter Kit Genuine Nicktane not A Copy | eBay
Since my truck parameters are stock I dont feel a $500.00 fass system is beneficial and this adapter and filter kit far outweigh's the stock filters capabilities for the price.
Taking out the check ball alone is a great improvement.
Thoughts.
TURBS
Goshen is my playground.
The last man standing also has a sharpie
Old 02-11-2014, 09:52 AM   #2
avolnek's Avatar
I would honestly suggest with your skills just find a filter head and cat filter to spin on to it of your choice. Then splice that baby in between the stock fuel filter and the injection pump... (sorry if you dont have an injection pump, i'm not terribly fluent with anything other than cummins...)
Most of the cummins guys I talk to do this route I suggested, none like the idea of running a fuel filter outside of the engine bay as we all here in the midwest experience freezing temps and the folks with the frame mounted pump and filter seem to be the ones that get screwed
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 02-11-2014, 10:20 AM   #3
The nicktane adapter is exactly that it adapts to the existing filter head to allow you to run a cat filter. I do not have one on mine yet but plan to in the future. The cat filters are cheaper than the stock plus you get better filtration.
bbritt18 is offline   Reply With Quote
Old 02-11-2014, 10:29 AM   #4
jevanb's Avatar
I have a nicktane adapter and been getting cat filters for 12 dollars
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-11-2014, 10:31 AM   #5
jevanb's Avatar
Get the spacer also because it is close to the block
you do realise fuel is pulled from your tank which bosh told GM to add a pump like dodge did (same CP3) you pump works harder to do both and the 3 little pumps inside like to have fuel waiting at the inlet , plus the added benefit of filter and water sep. I am running the airdog2 -165 and put it on the truck when it was only a year old or so, the engine runs smoother and no more priming
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 02-11-2014, 10:55 AM   #6
jevanb's Avatar
I got a case of these from a friend for 20 dollars and will use them up.. one is for the nicktane and the other is for the airdog
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 02-11-2014, 11:03 AM   #7
TURBS's Avatar
The spacer I ordered when I got the truck, to spacer out the gm filter housing.
TURBS
Old 02-11-2014, 11:06 AM   #8
jevanb's Avatar
the stock bolts for the spacer are too short so get longer ones from the hardware store just about 1/2 longer
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 02-11-2014, 11:23 AM   #9
Herk7769's Avatar
Hate to say this, but I would love to see an article with pictures on how this is done.
HAM CALLSIGN - KC3FFW
Old 02-11-2014, 11:27 AM   #10
TURBS's Avatar
Lou I'll email you the pdf.
TURBS
