Old 04-01-2013, 06:16 AM   #11
TURBS's Avatar
Originally Posted by wingriders View Post
351A
Was that GM part number?
Napa /precision number
Old 04-01-2013, 06:16 AM   #12
TURBS's Avatar
Originally Posted by jevanb View Post
did you have to use a torch and get the stuff out before you removed from the drive shaft??
Didn't have the plastic goo.
Just the clips.
Old 04-01-2013, 06:59 AM   #13
TURBS's Avatar
So just an fyi.
An otc ball joint/u-joint tool is to small to properly "without redneckin" to remove/install this joint.
The receiving end of the tool is to small for the cap to pass through.
Which is why I had to use the boxed end of a 1" 5/16 wrench as a spacer.
