09-21-2015, 10:11 AM
Easier maneuvering from the front of the TV?
Hi All,
I have a 2012 292 BHDS, TV is a 2011 F250 6.2 CC. My camper storage location is next to the house, in a tightly angled spot. I've put it there twice, both times it takes a good bit of time, and still have not gotten it exactly how I want it. I was looking into how to carry the bikes for all of us, and ran across front mounted (on TV) hitches. Not I wonder if maneuvering the trailer mounted to the front of the truck would be easier to get it into the tight space? anyone know if the front of the truck could handle the tongue weight? Would maneuvering be easier this way? It would definitely be different!
Looking forward to some good discussion!
09-21-2015, 10:43 AM
Left Coast
Sure it would......in both your questions
09-21-2015, 07:09 PM
I have one on the front of my tractor. works very well for moving trailers around. Just be sure the front hitch would handle your tongue weight.
09-21-2015, 07:18 PM
I have seen several PU's with a front hitch.
One was off set to the passenger side, I ask why.
Owner said, if the hitch was in the middle he would not be able to see without sticking his head out the window.
Off set allowed him to look down the side sitting upright.
09-21-2015, 07:24 PM
^^^Exactly!^^^
09-21-2015, 09:20 PM
We. Have a short driveway with a bend in it. Back in as far as I can go, drop the trailer,turn the truck around hook up and push it right in. Couls probable use the front reciever for a bike rack while on the road. I found its well worth the $$.
2012 F250 6.2 gasser 373 rear
2013 Rockwood 2104S Mini Lite
09-21-2015, 09:32 PM
I'll back up what the others are saying. Just for maneuvering around the yard I'd imagine it could handle the weight, first time you set the trailer on it you'll be able to see if it flexes too much.
09-21-2015, 09:49 PM
Thanks for all the replies. I'll likely investigate other options as well, but I like the idea of a bike rack and easier maneuvering. I was looking at this website www.bodiak.us. the tongue weight worries me though, as I think I'm at around 800 with the 292bhds.
09-21-2015, 09:52 PM
My "front hitch" isnt on my truck.I burned a 1" dia hole in the right fork of my skidsteer fork attachment,so i can put the ball on center or 2' to my right.Also allows for infinite vertical ball hight too,no running around cranking the trailer coupler up or down!
09-22-2015, 12:49 PM
as it should... I doubt that any front mount will handle that weight...
I have a front ball mount on my mid-size Kubota 4x4 tractor for maneuvering and my 550# tongue weight is just about all the front end can handle... easy to push the trailer but tough to turn especially tight turns with all that weight on the front end
2014 Shamrock 183
09-22-2015, 01:44 PM
Ive seen people do it all the time even on boat launches. Some people just don't like to back.
09-22-2015, 04:51 PM
09-22-2015, 05:23 PM
Hitch Hooks Replacement Hitch for Front Mounted Receiver Hitch
For the short duration and low speed one would use the front I would think it should be fine.
09-22-2015, 09:01 PM
RetiredRVer
If your 3/4 ton truck is equipped to handle a snow plow, it can handle your TT for that short duration and distance.
09-22-2015, 09:10 PM
I have a ball mounted to the skidsteer bucket.
Ride Safe, Wave, I'll Wave Back.
Retired Paramedic, Emergency Dept. Director.
2014 Work and Play 38RLS, Black, no decals.
2012 Ram 3500, diesel, 4X4, dually, black, de-badged.
1994 Harley Heritage Softail, black.
2014 Honda Pioneer, not available in black.
09-25-2015, 08:42 AM
Thanks. These look good, but look like you make your own? no drawings for an F250. I like the idea though!
09-25-2015, 03:39 PM
If I had the equipment to make one I think it would be easy, one could pull the hook off and use it for a template.
1/2 in plate for the base, burn a hole in the center for the receiver tube so you can weld it up in two places.
A brace under the tube for support.
Grade 8 bolts.
