Old 06-12-2016, 05:16 PM   #1
strat56's Avatar
Easy Question - 100 lbs
I took my new 2015 Ford F350 6.7 to the Cat Scales and went thru the Weighing Trinity of just TV, TV with trailer with WDH engaged and TV with trailer without WDH engaged. I then went to this web site, Travel Trailer Weight Calculator | Safety Report and entered the numbers along with the other data requested about my TV and everything looked OK as far as the capacities of the TV go.
I attached the PDF of the entire report but here's a picture of just the results and the part that I have a question about.
The results, this all looks great to me:
This displays the part I have a question about:
The front axle weight with the WDH engaged is 4800lbs, with no trailer it's 4900lbs. I'm wondering if this too much weight removed from the front end of the TV? It's about 2% lighter with the WDH engaged compared to with no trailer.
It took me a lot of trial and error to get to this point. I've got some stuff that I usually take I can move to the storage in the rear of the trailer, from the truck bed, to add a little weight to the back of the trailer and take some weight off the tongue but I don't want to if the 100lbs is not a big deal. What do you think?
File Type: pdf Travel Trailer Weight Calculator _ Safety Report.pdf (191.5 KB, 42 views)
Jack and Jan
Nights camped 2014 - 8 | Nights camped 2015 - 23 | Nights camped 2016 - 24
2015 Ford Super Duty F350 > Blue Ox Swaypro WD Hitch > 2015 Rockwood Windjammer 3008W
strat56 is offline   Reply With Quote
Old 06-12-2016, 05:29 PM   #2
I`d say 100 pounds is nothing to worry about. Now go out and have fun.
Big Red and 30WR is offline   Reply With Quote
Old 06-12-2016, 05:29 PM   #3
clr
First I am not a WDH expert but from your numbers I see no problem with your setup. You are well within your front axle rating in either case. So if this setup tows well I would say that you should be good to go.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 06-12-2016, 05:40 PM   #4
wbdavey's Avatar
I have a much lighter truck, and also toyed with front axle weights. As set up by the RV dealer, the front axle was within 200 pounds of the truck alone weight, but the rig didn't seem as stable as I would like. I adjusted the spring bars to push more weight to the front - now within 60 pounds of the truck alone and the rig has a lot more stability. My point is, try it as it is. If it seems a little "floaty" you can adjust your hitch and even a small change can make a noticeable difference.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 06-12-2016, 05:45 PM   #5
I go RV'ing not Camping
jgourlie's Avatar
X2. If it isn't towing well then worry, if it tows great go have fun
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 06-12-2016, 07:37 PM   #6
It is not a big deal at all. Leave it alone.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-13-2016, 02:24 PM   #7
strat56's Avatar
Thanks everyone. It was very windy yesterday as I drove around with this set up for a little bit so I really couldn't tell if the trailer was swaying or being blown around by the wind.
Going to Gettysburg PA next weekend and Shenandoah Valley in VA the following weekend. Guess I'll a pretty good idea how it pulls after that.
Jack and Jan
Old 06-13-2016, 02:26 PM   #8
strat56's Avatar
Jack and Jan
