10-09-2014, 04:46 PM
Eaz Lift sway bar???
We just purchased our HG 312QBUD and the dealer installed the required hitch with one sway bar. Our trailer weight is over 6K LBS. My questions is do we need to install second sway control and it was suggested on the EAZ sight, anything over 6K needs two sway bars?
10-09-2014, 04:52 PM
Hi,
Did you purchase a weight distribution hitch like an Equalizer 4 point? If so, what type?
Makes all the difference on the required sway bars.
I have the Equalizer 4 point and do not require a sway bar but I did need one with my old chain style hitch.
crunchman
2015 F-250 FX4
10-09-2014, 04:55 PM
I have the easy lift with the chains and want to change any recemondations on a easy lift with out chains
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
10-09-2014, 05:02 PM
We have the EAZ weight distribrution hitch with spring bars and sway control right side
Big Paul,
If you mean you are looking at changing your hitch type, I love my Equalizer like many here but other's like the Reese SC Weight Distribution w Sway Control - Trunnion
You can search the forums above for opinions.
crunchman
2015 F-250 FX4
10-09-2014, 05:09 PM
I am wondering having a trailer over 6000 lbs do we need two sway bars? I just want to be safe going down the road. EAZY lift sight recommends two sway controls for anything over 6000 lbs. Does anyone have two sway bars on thier rig?
10-09-2014, 05:17 PM
I added a 2nd sway bar that I bought from Harbor Freight for about $40 and I am really happy with it. Having the two bars adds another 45 seconds to the set up but it makes a nice difference.
Mark and Joanne
10-09-2014, 05:20 PM
Thanks Mark S
10-10-2014, 11:33 AM
Just to let everyone know the dealer said I needed two sway bars and they missed it. They are installing second one at their cost .
10-17-2014, 09:04 AM
I use the Easy lift with chains and 1 sway bar on a 33' trailer wt. about 7500 loaded . I have had no problems .
10-17-2014, 09:28 AM
That's great a good dealer that fixes it's mistakes. When it comes to this there's never enough, had 2 on my #4000 trailer now a #6000 trailer and kept the same setup seems to work good.
Think about things before you do them make life easier not harder.
10-17-2014, 10:03 AM
That is good to know that you have not had problems Yet with only (1) sway bar. When a sway problem does occur it will be to Late to place the (Second Sway Bar) as (Recommend by the Manufacture)! Youroo!!
10-17-2014, 11:17 AM
I had no problem either, but the recommendations say two. Safety first
10-17-2014, 07:12 PM
I've used mine with the Eaz Lift, and no sway bar several times, and don't notice any difference. My trailer in about 30' and now at 7,000#.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
10-17-2014, 08:32 PM
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
I pulled a 30 ft Jayco WhiteHawk with the EAZ Lift system....7800# loaded....1240# tongue weight.....used 1400# bars and one sway bar....never had a problem with towing...have now traded for a 5th wheel.
Lloyd & Kathy Martin
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014-38nights/3500 mi; 2015-66nights/6260 mi;2016-44 nights/6106 mi;2017-65nights/6992 mi;2018-47nights/7376mi;2019-65nights/7825 mi;2020-59nights/4142mi;2021-39nights/3072 mi;2022-59-nights/6149 mi;2023-36nights/3001miles.
10-17-2014, 08:56 PM
I wanted a fifth wheel but the dealer informed me there was no hitch available for short bed with ram boxes
10-17-2014, 09:20 PM
Check B&W. Their set up is a gooseneck receiver that a 5th wheel slides into.
I use one and have had no issues. They're American made and well built. I work in the oilfield and we only use B&W receivers. Their gooseneck set ups out last the pickups.
Sent from my high tech gadget
11-15-2014, 08:06 AM
I have the same set up EZ-Lift with chains ,on a 33 ft 7500 lb trailer 1 sway bar works fine but thinking about adding a second just for more peace of mine. Been using this one 3 years.
