02-22-2017, 03:16 PM
Eco boost timing chain
Buddy has his F-150 eco boost in for timing chain replacement, mech said this is fastest and least expensive way to replace. Job was done in seven hours.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
02-22-2017, 03:22 PM
I knew the cab had to be pulled for the diesels, did'ny know about the ego boost
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
02-23-2017, 11:35 AM
Wow.. How many miles are on his truck that it needs a timing chain replacement?
IM guessing thats about 850 bucks or so in labor alone..
02-23-2017, 11:49 AM
SOP now. Used to be the later model (after 1999 Super Duty Diesel) had to have the cab pulled but with thew short hood and all the crap under the cowl, they all get pulled. The price you pay for a short hood and recessed engine....
Couple body mount bolts, rad hoses, and odd stuff and off it comes.
02-23-2017, 12:03 PM
He has about 175000 kms which is around 108000 miles, price was just over $1000.
2014 Forester 3051s
2012 Sonic toad
02-23-2017, 01:05 PM
Dr Travel
Mileage & timing chain
Wow - that's pretty low mileage for a chain replacement. An awesome process to do the job!
Glad I got my extended warranty from Ford, good till 125K miles. Sitting at 72K so figure if I need a new chain around 110K miles I'm good. Still, that is quite the repair job...thanks for sharing the experience.
02-23-2017, 01:19 PM
There was a thing about this a while back, something about the timing chain making a horrible racket. I took my 2011 with about 70,000 km on it. It wasn't really making much noise , but they changed it anyway. The advisor said they were slow so they didn't mind the work. I got a new chain out of it, plus they flushed the radiator. They did take the cab off though. They had it for two days. Under warranty so no charge.
02-23-2017, 01:23 PM
That was the problem with his, it sounded like a portable cement mixer in there.
2014 Forester 3051s
2012 Sonic toad
02-23-2017, 03:13 PM
EcoBoost
I just changed mine, 3.5L 2011, the chain is nearly 6 feet long and mine streached by 2 inches, chain tensioners were at the limit.
Did all the work my self, under the hood, It took me a couple of days but runs great now, even though the performance never suffered, just the rattle when starting.
It had 77,000 miles on it. Should last a long time, changed everything, all tensioners, the hydrolic tension control and all other items related to the timing chain.
~$250.00 in parts and rental on specialized tools.
Ken
2011 Ford F150 EB 3.5 3.73
2016 Forest River Cruise Lite 273QBXL
Equalizer E4 10000 Hitch
Central Texas
02-23-2017, 03:40 PM
The new engines are designed for ease of assembly (cheap and quick) with little thought about fixing them.
I'll stick with a good old style pushrod motor.
02-23-2017, 03:57 PM
Hate to see that... have a hard time believing everything is whole after pulling the cab.
02-23-2017, 07:08 PM
2015 on up F150's the engine is easier to work on. 2017 they completely redid the 3.5 ecoboost. The only thing that is the same is the actual 3.5 designation. The whole inside is brand new including new and lighter turbo's. The early Eco's, the timing chain was the weak link. I had a 2013 that was just starting to make a ticking noise at idle which is a clue the chain has stretched according to one of the mechanics I spoke with at the dealer. My new one is quiet as a mouse.
02-23-2017, 11:56 PM
5w40 weight oil should help your chain last longer. I've owned 2 Ecoboost F150's and ran 5w40 in both of them.
02-24-2017, 05:11 AM
Good luck getting them to warranty a wear item.
2014 RAM 3500 4x4 CCLB Dually, Cummins / 68RFE / 3.42 / B&W Patriot 16K
2016 Coachmen Chapparral 360IBL
SOLD - 2012 Salem Cruise Lite 281BHXL
SOLD - 2005 Dodge Ram 2500 4x4 QCLB Cummins
02-24-2017, 06:52 AM
Where do you plan on buying one of those? Pretty sure there are no trucks anymore that come with a push rod engine.
David & Lynn 2014 Coachmen Chaparral Signature 327 RLKS 2016 Ford F350 Lariat CC Dually
02-24-2017, 06:57 AM
Hemi and GM are pushrod V8's last I checked.
02-24-2017, 07:09 AM
Is it a timing chain or timing belt??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
02-24-2017, 07:19 AM
My 2011 EB has 153,000 miles on it. It will occasionally rattle for a few seconds on start up and then settle down. Has done that for years.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
02-24-2017, 08:49 AM
It is a chain.
Cheers, Jim and Sandy
'14 F150 FX4, '15 Coachmen FE29SE
02-24-2017, 08:53 AM
The last I knew pushrod engines had timing chains too.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
