Originally Posted by Davepasch
Not sure if it's a good idea to have tow/haul, engine brake, exhaust brake in use with the cruise control on.
These engines are designed to be used with tow/haul, exhaust brake, and the cruise control on, at least the Cummins is. In the newer trucks for Ram from 2013.5 and up, when the two speed exhaust brake was introduced by them. The brake was advertised to maintain the truck at the set road speed as you go down hill with everything engaged. This was from the engineer who designed the system at the "TDR" rally held in Columbus IN at the Cummins plant. The other set point is for more aggressive braking when required.
This was all tested to the SAE J2807 standard.
I run my truck this way since new in 2008, I now have 106,000+ miles on the OD. If you do not run the exhaust brake on these trucks you will have emission issues and check engine lights all day long.
